Lost my heat
Old Feb 5, 2007 | 09:28 PM
GrtWht91's Avatar
GrtWht91
Default Lost my heat
I installed the super ram a while back and i live in Florida so i dont worry about the heat a whole bunch, but recently its been a little cold and been missing my heat, im not sure what i missed when installing the superram but the heat does not work, anyone have advice or diagrams of how the heater hoses run? Thanks
Old Feb 5, 2007 | 10:25 PM
pablocruise's Avatar
pablocruise
Go under the hood and remove 3 screws on this:
Have someone in the car switch the temp from 60 to 90.
Look down inside the cavity/box. You want to look for this door moving
btw, you mentioned doing the S/R. Did you connect the vacuum line for the climate control back up?
(*note on pic: there should be a 90* elbow on the end of that line as well as a one-way check valve)
Old Feb 5, 2007 | 10:40 PM
GrtWht91's Avatar
GrtWht91
Im going to do this tomarrow asap, and i did connect all the vacuum lines back including the one for the climate control
To Lost my heat
