Hurst Shifter Install without removing the exhaust?
Old Oct 5, 2001 | 10:44 AM
89vette's Avatar
89vette
Default Hurst Shifter Install without removing the exhaust?
I have an 89 Vette with an LT1 Corsa cat back. Has anyone installed the Hurst Shifter without removing the exhaust? It looks very possible on my car.
thanks,
Jason
Old Oct 5, 2001 | 02:27 PM
1991Z07's Avatar
1991Z07
Default Re: Hurst Shifter Install without removing the exhaust? (89vette)
While "technically" it is possible, Chris will tell you that you'll save yourself at least an hour in installation time by dropping the exhaust out of the way. Since the exhaust only takes about 10 minutes to get off, I'd say you'll be way ahead.
Old Oct 5, 2001 | 07:39 PM
LT4Sam's Avatar
LT4Sam
So long as you have sufficient room to access the lower boot and drive out/in the pin you should be okay. Then you'll also need room to get the zip tie's back on. If you feel you've got the room to do all that, good for you, otherwise drop the exhaust.
Sam
Old Oct 5, 2001 | 10:29 PM
Justin Scherer's Avatar
Justin Scherer
I would not recommend it unless you are a professional mechanic (or so skilled) and/or you have done one of these shifters before. Its maddeningly tight quarters up in there (dirty and blind too). You not only have to deal with the pin (which can be stubborn), you have to deal with the clip too that holds it in place. Having done it before (with the Ripper) I still can't imagine doing it with the exhaust on. Here's my torture story. Perhaps it will help you avoid some pitfalls: http://www.snowdirt.com/corvetteshifter.html
(the pinning/unpinning should be the same as the ripper)
Justin
Old Oct 6, 2001 | 09:55 AM
Tony.96LT4's Avatar
Tony.96LT4
Did my '96 convert without dropping the exhaust. It was really tight. :smash: Next one I do, the exhaust is coming down. :yesnod:
:flag
Old Oct 7, 2001 | 12:34 PM
89vette's Avatar
89vette
Default Re: Hurst Shifter Install without removing the exhaust? (Tony.96LT4)
Thanks guys. Revoving the new exhaust looks as though it will be quite challenging. The cats are slipped on but the pipe coming out of the cat is welded then clamped to the resonator. I'll have to remove it from the rear forward. I guess its worth a try to remove it if it makes it that much easier. I think though that R and R of the exhaust will take more than an hour.
Old Oct 8, 2001 | 05:32 PM
1991Z07's Avatar
1991Z07
I've taken my exhaust off as a single piece 3 times now. All you need to do is drop the 4 bolts from the center hangers, loosen the cat clamps then drop the rear brackets and wiggle the system out.
I would suggest that you use your second lifeline and "call a friend" to assist you in the operation. :lol:
Took me a total of about 10-15 minutes each time to remove the system. If you pull it complete, it also lines right back up without any work.
To Hurst Shifter Install without removing the exhaust?
