My L98 has the AIR pump and AIR tubes on the exhaust manifolds.
Do the LT1/LT4 exhaust manifolds have the same AIR tube provisions?
what I'm getting at is, If I had a free LT4 exhaust, would it bolt up to my L98 with AIR tubes? (some earlier searching says yes it will bolt up to the aluminum heads, but I was unable to find the AIR tube answer...)
The headers should bolt on, and the AIR system should hook up to the backfire valves on the LT-1 tubes. However, there is that pesky EGR problem. (You won't have one)
Thanks!
IF you have air tubes in each port, the LT1 does not. There is 1 connection per header and it points straight up. You might be able to mock something up, though.
