Un-driven vette ~1year gas question
Old Feb 6, 2007 | 08:02 PM
Just_Sublime's Avatar
Just_Sublime
Default Un-driven vette ~1year gas question
Hey everyone,
im sure this will disturb many people (im disturbed too) but ive recently acquired a:
1993 corvette automatic
the car has just over 100k miles, and has been undriven and practically unstarted for around a year.
it has been garaged prior to and during my ownership. it had at least 5 gallons of gas in it when i got it, and a bad battery. I got it, and put it in my garage. replaced the battery, and it starts fine. it chugs like crazy when on though, therefore ive only left it on for merely a minute or so at a time.
so i figured it was bad gas (at least) i siphoned the gas out tonite (still ~2 bars on the digital reading left in it when i started it briefly) and i have 2 portable gas tanks with super unleaded in it that i got recently.
I want to know if i should have this car directly towed to a professional or if i should fill it with the new super i got, and turn it on, and drive it to a nearby shop i've taken other cars (for fluid checks...oil change, etc)
any information is appreciated its in very good shape, the auto transmission was replaced just 3-4 years ago, and i want to treat it right.
thank you
Old Feb 6, 2007 | 08:09 PM
C4Robert's Avatar
C4Robert
i would say put in the new and try it out if it is still rough then call the tow but if not the just take it up there under its own power. and don't let her sit for another year this time. if you don't want to drive her send her here ill take her off your hands
Old Feb 6, 2007 | 08:28 PM
85vet's Avatar
85vet
Cruise-In V Veteran
Change the gas filter & run some good injector cleaner through it. I bet after 2 tanks you will be fine.
Old Feb 6, 2007 | 08:44 PM
Bob CTS's Avatar
Bob CTS
Fill it up and drive it with cleaner added. That time period and being garaged is not that bad on gas, open the cap and smell it, if it was going bad or bad you will know, bad gas has a hell of a putrid smell.
Old Feb 6, 2007 | 08:52 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
, mine went for a year. i put fresh gas in it, after the second tank it was back like new
Old Feb 6, 2007 | 08:53 PM
VenkmanP's Avatar
VenkmanP
Put a half tank of fresh gas in before you run it, then drive it to the gas station and top it off.
Old Feb 6, 2007 | 09:05 PM
KCHOTBOAT's Avatar
KCHOTBOAT
fill it with fresh gas and add octane booster. With boats we have done this all the time there are only a few good octane boosters and off hand I don't remember the brand name of a true octance booster and maybe someone else will. Gas looses octane as it ages.
Old Feb 6, 2007 | 09:25 PM
Just_Sublime
thanks a lot, i actually dont know how to change the gas filter, but ill research that.
c4robert i wish i had my hands on it before it was sitting for so long
anyone have any recommendations for gas cleaner/octane boosters? im sure i can just find something at the local store but i had to ask.
a lot of great responses very fast. thank you this vette will be great in no time especially with corvetteforums advice
Old Feb 6, 2007 | 09:46 PM
KCHOTBOAT's Avatar
KCHOTBOAT
Tolulene and Torco are two that are true octane boosters.
Old Feb 7, 2007 | 08:32 AM
Desert1957's Avatar
Desert1957
Desert
Old Feb 7, 2007 | 09:49 AM
rickneworleansla's Avatar
rickneworleansla
There is a tech tip on changing the filter. It is located underneath by the passanger side cat. In my 95 vert I relieved the gas pressure by pulling the fuse and running it and then at the relief valve by the fuel rail. Undo the gas cap in the rear also. After that I removed the braided gas line that is attached to the filter from the top of the engine and removed the bolt at the rear of the filter. I then pulled the filter with the line connected out through the bottom of the car. This was for a vert which is in a more difficult position to get to the top filter bolt. On a coupe you can probably remove it without the line attached.
Good luck
Old Feb 7, 2007 | 10:29 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default gas
there is a product called Berryman's Chem Tool.
Theis is a really good additive. It will absorb water, and allow it to be delivered to the gas stream in tiny particles, clean the injectors, and dissolve deposits.
BUT do not add this product in a large quantity compared with the amount of gas that you have in the tank. 1/4 of a can to a tank.
that will begin helping, and will start the process. run the tank dry, and refill with fresh gas, and add half can.
This product may eat away at your fuel hoses if it is administered in large quantities, but does not affect the hoses if used in smaller administered doses because it is dissolved in gasoline in an appropriate amount.
you wouldn't use a whole bottle of aspirin for just one headache, right? but in a year u will use the whole bottle. same effect.
Chris
Old Feb 7, 2007 | 10:56 AM
caa5030's Avatar
caa5030
As far as fuel injector cleaners go I have had good luck with the cheveron techron fuel injector cleaner.
Old Feb 7, 2007 | 03:59 PM
BigDR's Avatar
BigDR
Default Red Line Fuel System Cleaner
I like Red Line. I'll bet you have water in your fuel filter. New filter, fresh gas.
Old Feb 7, 2007 | 04:05 PM
Just_Sublime
thanks for all the great responses, going to get some things at the car store right now.
just for clarity should i fill it with as much new gas as possible then add the booster, should the booster go in first because there is still the bad gas in there that i could not siphon out?
im not decided yet on how much i will tinker with the gas filter, as you all have probably realized already im very much an amateur. but i had forgotten about the great tech tip articles/etc. on this site so i will definitely be looking at them
Old Feb 7, 2007 | 04:07 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Mine fired right up after being in storage for a year. That was out in the desert though, not much moisture in the air. I added some gas additive when I got it back east. I'm not driving it much right now, I plan on changing the filter as soon as it gets about the freezing mark.
Old Feb 7, 2007 | 05:54 PM
hgh pwr's Avatar
hgh pwr
just sublime I'm in palm harbor if you need a hand. Where are you at?I'm off of belcher and alderman.
To Un-driven vette ~1year gas question
Old Feb 7, 2007 | 06:07 PM
rws.1's Avatar
rws.1
Berryman's Chemtool B-12 is available at Walmart for about $3 , or use SEAFOAM. available at most autoparts stores for about $7 or Valvoline Synpower fuel system cleaner $9 at most autoparts stores. Add it to the tank, then your fresh gas, then go fill up with premium
Old Feb 7, 2007 | 06:35 PM
Just_Sublime
i was only able to find an stp fuel cleaner product at the local autostore, stp had an octane booster as well, but i chose this.
rws i did see seafoam, but i chose stp , would you recommend i bring it back? i havent used it yet ive been very hesitant about anything i do to this beautiful vette.
highpwr, i lived in palm harbor a long time, im now in port richey, a good distance away, do you have an email? im at just_sublime@hotmail.com
ill be holding off another day as far as adding the gas/cleaner goes just want to make sure i dont damage the engine at all
thanks again great website and community
Old Feb 7, 2007 | 06:56 PM
Road Agent's Avatar
Road Agent
Top it off and drive it! Should be fine.
