Lowering... Rear Spring Bolts...?
Old Feb 6, 2007 | 11:45 PM
A BirdMan Converted's Avatar
A BirdMan Converted
Default Lowering... Rear Spring Bolts...?
1996 LT4 Z51 Coupe
So my car was lowered before i bought it. the guy used a guldstrand lowering kit.
Question 1: are the standard lowering bolts 10"
I now plan to relower the rear farther, mainly so the passenger side will sit at the same height as the driver.
Question 2: What is the thread pattern...? so i may get some even longer grade 8 bolts from a hardware or specialty store...? 12" long or so
-Kevin
Old Feb 7, 2007 | 12:43 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
The factory bolts are 14mm. The aftermarket ones might be too or they could be 9/16" which is very close to 14mm. I use 16mm bolts that are over 11" long and I assure you they are plenty long. I could drop the quarter panels onto the tires if I wanted to. VB&P offers 11" bolts I believe.
Old Feb 7, 2007 | 05:49 AM
GS348's Avatar
GS348
Default Vb&p
Go to VBP, Vette Brakes and Performance. I need to do the same thing. I have lowered the rear with the 10" bolts and will be putting in the 12" bolts soon. If I remember right, they are about $60-$70; which sounds high, but I feel its well worth it. BTW, you can request a free catalog, very cool stuff for brakes and handling, very cool
Old Feb 8, 2007 | 06:34 PM
A BirdMan Converted
They Are $79.95 for the bolts only. plus S&H
I found a local place that sells 9/16 x 12" grade 8 Natural finish bolts for $6 each!(not $40 ea.)
Those should work... I would just need matching nylock nuts.. Right?
Old Feb 8, 2007 | 11:15 PM
A95Y's Avatar
A95Y
Yep
Old Feb 10, 2007 | 12:47 AM
A BirdMan Converted
Originally Posted by cheetah
Yep
Is there a special place i should get the 9/16 nylock nuts?? or can i just use regular locking nuts...?
Old Feb 10, 2007 | 12:51 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Try Lowe's or a good local hardware.
Old Feb 10, 2007 | 12:54 AM
A95Y's Avatar
A95Y
I suppose a regular locking nut would suffice. I just went to the Handyman Hardware store (there is a very good one nearby, luckily), but I think
I have seen them at Sears. Handyman Hardware is best for any special items I need. If they don't have it, they can usually get just about any nut or bolt you need.
Old Feb 10, 2007 | 01:43 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
go to Fastnal and get the bolts, washers, locking nuts all grade 8 or even 10, complete set $15.00 delivered... and much better and harder grade...
To Lowering... Rear Spring Bolts...?
