fuses that will prevent starting
Old Feb 7, 2007 | 01:42 PM
choopes's Avatar
choopes
Default fuses that will prevent starting
On my '93 there is the obvious fuse panel of the passenger side interier. I also found some fuses just to the left of the battery. Are there any other fuses that would prevent ignition? Anf where are they located? It turns over, but little or no fire at the plugs or coil. New coil, wires, ICM. Opti was changed about a year ago. Has about 1000 miles of use since the opti and water pump were changed.
THANKS!!!
