LT1's have EGR????
Old Feb 7, 2007 | 07:46 PM
garkahn90's Avatar
garkahn90
Default LT1's have EGR????
I was going to put LT1 exhaust manifolds on my L98 along with the rest of the LT exhaust system. But, it looks like the L98 EGR is piped off the passenger side exhaust manifold and I don't see any fitting on the LT1 manifold I have.
Old Feb 7, 2007 | 08:09 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
You may be able to adapt the pass. side AIR tube to work as an EGR source. Actually the AIR doesn't do that much, but the EGR is pretty important for emissions and driveability.
Old Feb 7, 2007 | 08:13 PM
garkahn90's Avatar
garkahn90
I was looking at that as a possibility. I will probably be taking off the air system anyway. But, I don't think it would be an easy plumbing job to go from the air fitting to the egr manifold inlet. That is all hard piped.
Anyway sounds like the answer to my question is no EGR on LT1's?
Old Feb 7, 2007 | 08:18 PM
Benny42's Avatar
Benny42
LT4's don't have EGR, LT1's do. Those manifolds came from a '96 6-speed.
Old Feb 7, 2007 | 08:23 PM
STL94LT1's Avatar
STL94LT1
There is no difference in the LT4 and LT1 exhaust manifolds. Although the LT4 doesn't have an EGR, it has the same AIR system as the LT1.
Old Feb 7, 2007 | 08:29 PM
Benny42's Avatar
Benny42
Ok. Which LTx manifolds don't have egr?
Old Feb 7, 2007 | 08:36 PM
STL94LT1's Avatar
STL94LT1
All LTx exhaust manifolds have air fittings. The LT1 also uses the air fittings for the EGR.
Old Feb 7, 2007 | 08:39 PM
Benny42's Avatar
Benny42
Thanks for the info. benny
Old Feb 7, 2007 | 09:49 PM
Road Agent's Avatar
Road Agent
What?
Old Feb 8, 2007 | 06:05 AM
garkahn90's Avatar
garkahn90
So, now it sounds like the answer to the question is yes, the LTx's do have EGR. But, they do not have a unique port in the exhaust manifold, instead they share the same plumbing as the air system?
Old Feb 8, 2007 | 09:13 AM
zr1fred's Avatar
zr1fred
Yes
Old Feb 8, 2007 | 12:17 PM
garkahn90's Avatar
garkahn90
Any suggestions on how or what to use for plumbing the EGR from the AIR port on the LTx exhaust manifold to the intake on the L98?
To LT1's have EGR????
