R&R Headlight Dimmer Switch
Old Feb 10, 2007 | 03:38 PM
LabDaddy12's Avatar
LabDaddy12
Default R&R Headlight Dimmer Switch
It appears that I need to Replace my Headlight Dimmer Switch on my 1991 ZR-1. Does any have instructions that they can share or diagrams of the upper steering column showing the Dimmer Switch?
Thanks.
Rusty.
Old Feb 10, 2007 | 05:22 PM
bogus's Avatar
bogus
it's all in the FSM. www.helminc.com.
It's not that hard... I did a tech tip on it.
Also, replace the pins for the tilt wheel.
Finally, what broke? The dimmer is remote, it's not at the stalk. The stalk simply pulls a rod that activates the dimmer. Check what broke before spending $120+ on a new multifunction switch (MFS).
Old Feb 24, 2007 | 05:21 PM
LabDaddy12's Avatar
LabDaddy12
I checked the dimmer switch and it is working properly and the rod is securely in place on that end. Now I guess it's time to check the signal light lever end of the rod.
To R&R Headlight Dimmer Switch
