I just finished up the three piece March underdrive pulley install on my 85. No major problems with the install...other than I found the crank pulley only had two of the three outer bolts on the pulley , it still had the center bolt. The two outer bolts came loose VERY easy , The car now seems to actually charge a little higher than stock at idle.
For those of you that install the three piece set in the future, your new belt is a Goodyear #4060855 6PK2170. I started with a belt 3" shorter than stock which would have worked. But there was not much tension left if it streached, so I went another inch shorter.
We will see what this does at the track, but it will be a partial test because I should also see a gain from my custom "slim line high flow racing cat". That is another future post as soon as I finish it up, I will post some pictures .
Three piece aluminum #4445. I bought them direct from March $220.34 plus $13.14 shipping. I couldn't find anything used. If you find them used, they are gone quickly.
