87 Cruise Control Problem, any ideas??
Old Oct 6, 2001 | 04:30 AM
TIMSPEED's Avatar
TIMSPEED
Default 87 Cruise Control Problem, any ideas??
The cruise control doesn't work on the 87 I'm about to buy, any ideas on what to check to see if maybe I can fix it? Thanks in advance
Old Oct 6, 2001 | 09:56 AM
CaneinBatonRouge's Avatar
CaneinBatonRouge
Default Re: 87 Cruise Control Problem, any ideas?? (TIMSPEED)
Could be the Cruise control servo(about $220) located above the battery resembles a ufo, or could be a vacuum problem. Check and see if you have the big black vacuum ball in the driver's side front by the headlights and that the vacuum line from the servo is connected. :seeya :flag
Old Oct 6, 2001 | 12:56 PM
scorp508's Avatar
scorp508
Auto or stick?
Old Oct 6, 2001 | 01:23 PM
KYVette90's Avatar
KYVette90
Default Re: (scorp508)
Unplug the connector on the servo and clean it a little and then plug it back in. This is how I fixed mine.
Old Oct 6, 2001 | 05:08 PM
TIMSPEED's Avatar
TIMSPEED
Default Re: (KYVette90)
Never knew they had Cruise Control on a stick...
yeah, that's what I figured, just clean the connectors.
Old Oct 6, 2001 | 05:26 PM
LTDan73's Avatar
LTDan73
Cruising
Also if a taillight is out thecruise control is deactivated as some sort of safety feature so I hear.
Old Oct 6, 2001 | 08:02 PM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
on my '85 there was a vacuum hose that runs to the brake pedal switch that had rotted out. It runs under the master cylinder through the firewall. I replaced it with some fresh vacuum hose and it worked again.
Old Oct 6, 2001 | 08:51 PM
scorp508's Avatar
scorp508
Default Re: (TIMSPEED)
Yup, if you barely touch the clutch or brake, it turns off.
Old Oct 6, 2001 | 09:10 PM
A's Avatar
A
Mine does: 1987 4+3 coupe.
Old Oct 6, 2001 | 09:12 PM
scorp508's Avatar
scorp508
Default Re: (A)
Me too. It wasn't really an option if I remember right, you just plain GOT IT.
Old Oct 6, 2001 | 09:47 PM
A's Avatar
A
Hey scorp, does your cruise seem to pulse? Say I set it to 70 mph it'll back off to 69 and add some gas and go at 70 for a while then back off to 69 yada yada.. :confused:
Old Oct 6, 2001 | 11:26 PM
Marcho Polo
Former Moderator
Default Re: (A)
My '85 did that.... but the return spring on my BBK throttle body was pretty stiff compared to stock and I just figured the cruise had trouble holding it steady.... but it was so annoying sometimes that I just didn't use it.
To 87 Cruise Control Problem, any ideas??
