New drag times
Old Feb 12, 2007 | 01:05 PM
djxib's Avatar
djxib
Default New drag times
1992 LT-1 with supercharger.
Got to the track on Saturday with the new Injectors and an initial tune. There is some spark still backed out while I address a small fuel pressure issue (so more to come!)
Anyway; I posted the following on my second run:
R/T .127
60' 2.175
330 5.671
1/8 8.435
MPH 91.96
1/4 12.649
MPH 118.83
Running street tires, 6 year old Good Year GS-C, 315-17 on the rear: no burn out, accidently left Traction (ASC) switched on (D'oh)
She pulls like a train and I think I could easily get into 11's if I improved my launch and my shifting.
From the numbers above - does anyone have any guidance?
Thanks!
Andy.
Old Feb 12, 2007 | 01:16 PM
mcnulty95's Avatar
mcnulty95
Ha Ha, I've forgot to turn off the traction control before too. Nice reaction time. I'm sure you will be in the 11s soon.
Old Feb 12, 2007 | 02:41 PM
pr1mu5's Avatar
pr1mu5
R/T .127
60' 2.175
330 5.671
1/8 8.435
MPH 91.96
1/4 12.649
MPH 118.83
Thanks!
Andy.
Get some Drag Radials for your rears... you'll gain half a second just from the added traction on your launch... you should be getting 1.9 in your 60' times, I believe, with the right traction. Burnouts are half the fun in drag racing
Old Feb 12, 2007 | 03:30 PM
GeosFun's Avatar
GeosFun
Yup, traction is the next culprit to address. Your mile an hour is telling you the engine is making plenty of power, so I'd concentrate on 60-footers. Tires and gear ratio. I'll bet there is around a half second to be found there.
Old Feb 12, 2007 | 04:21 PM
Jim McCombe's Avatar
Jim McCombe
The mph is a good gauge that tells you that you have a car that is capable of ET's in the sub 11.50 range and from the information that you supplied, you are getting a lot of tire spin.
Eliminate that and hang on!!!
Keep in mind that if you are racing at a NHRA sanctioned track, a roll bar will be required once you hit 11.49 or quicker.
To New drag times
