Oil Change Time
Old Feb 12, 2007 | 07:32 PM
Fast Cop's Avatar
Fast Cop
Default Oil Change Time
OK I am getting ready to do my pre summer oil change. In the past I have run Mobil 1 5w40. I am thinking of running the Mobil 1 10w40 due to the weather here in South Carolina. Any thoughts or issues I might be missing. As always, thannks in advance.
Old Feb 12, 2007 | 09:24 PM
SJW's Avatar
SJW
If it's a stocker, and street-driven only, Mobil 1 5-W30 would be my recommendation.
Be well,
SJW
Old Feb 13, 2007 | 07:32 AM
BerniesVette's Avatar
BerniesVette
The manual for my 92 recommends 10/30 for temps from 0 degrees up.
Bernie
Old Feb 13, 2007 | 07:55 AM
KeyWestJack's Avatar
KeyWestJack
I think you are on the right track.
Old Feb 13, 2007 | 08:21 AM
RRT vette's Avatar
RRT vette
Old Feb 13, 2007 | 09:31 AM
enventr's Avatar
enventr
The manual calls out for 5W-30
Old Feb 13, 2007 | 10:15 AM
runner140*'s Avatar
runner140*
The "General" put in Mobil 1 5W30 from the factory. Go with what got you here.
Old Feb 13, 2007 | 12:13 PM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
I would go with which ever was cheaper bc there is very little difference between them
If the same price just go with what the manual says
Old Feb 13, 2007 | 02:57 PM
Perfusion's Avatar
Perfusion
I'm not sure what weather it is in S. Carolina that you're concerned about, but I'll assume heat & humidity. I grew up in GA, so I know how hot it can be. That said, the south has *nothing* on AZ in July (except humidity), and I always ran 5w30 when living there. If people in AZ and SoCal run 5w30 sans problems, you certainly don't need 5w40. Switching to 10W-anything from 5W-same will only cause more wear at startup. You want the least-thick oil at startup as possible.
Here's some good reading for you:
(The following is a single chapter from a multi-chapter series written by Dr. Ali Haas and posted on FerrariChat.com. I am citing it because I think it does an excellent job of breaking down complex principles (for some) into "layman's terms.")
http://www.ferrarichat.com/forum/sho...41&postcount=1
Old Feb 13, 2007 | 03:51 PM
teufelhund's Avatar
teufelhund
I went with Royal Purple 5w-30 and my car actually feels better. It revs alot smoother. JMO
Semper Fi
To Oil Change Time
