Lowering the rear
Old Oct 6, 2001 | 07:03 PM
blk1996vette's Avatar
blk1996vette
Default Lowering the rear
This has probably been discussed many times but I didn't catch it. I look through the Echlers catalog and see 10 in bolts to lower the rear. I want to lower it about 1 in. How hard is this ??? :confused:
Old Oct 6, 2001 | 07:05 PM
BobMachus's Avatar
BobMachus
Default Re: Lowering the rear (blk1996vette)
So much easier than you could possibly imagine. You will need a jack, jackstands (or some other way to keep your car in the air) and a couple wrenches, that's it! The front is another matter, however.
Old Oct 6, 2001 | 07:21 PM
blk1996vette
Default Re: Lowering the rear (BobMachus)
Thanks for the info. I am only doing the back. ;)
Old Oct 6, 2001 | 07:31 PM
tempest's Avatar
tempest
careful when lowering only the rear. too much will screw with the aerodynamics enough to make the rear end feel loose...
To Lowering the rear
