Differential Questions
Old Oct 6, 2001 | 11:49 PM
IcemanZ06's Avatar
IcemanZ06
Default Dana44 Technical Questions
I have a few technical questions regarding the Dana44.
How many bolts is the corvette rear end?
How large is the rear end? 8.5"?
What size carier does a 3.54/3.73 gear require.
How many teeth and gears does it have?
How many splines are the axle?
I need as much information about the technicals of the corvette rear diff.
[Modified by IcemanZ06, 10:16 PM 10/6/2001]
Old Oct 7, 2001 | 12:47 PM
IcemanZ06's Avatar
IcemanZ06
Default Re: Dana44 Technical Questions (IcemanZ06)
With the amount of people here who have made the switch, someone should know. Thanks in advance.
Old Oct 7, 2001 | 01:17 PM
Fla96LT4's Avatar
Fla96LT4
I just completed R&R of the differential on my 87. I recall (from my search for data) that this information is available at the Dana web site and possibly Tom's Differentials, as well as other places. This site has a great deal of information as well.http://www.imajeep.com/axles/axles_and_gearing.htm
Hope this helps! :D
Old Oct 7, 2001 | 05:05 PM
BBA's Avatar
BBA
Default Re: Dana44 Technical Questions (Fla87)
I've got a D36 apart here...looks like the case has 8 bolts that seal the cover. It has 10 bolts that hold the ring gear to the carrier.
The number of teeth for that ratio...I don't know. I guess that would depend on the gear design/helix angles, etc...
Do you have a set of gears you are trying to analyze? Not trying to insult your intelligence, but if you werent sure, the number of ring gear teeth divided by the number of pinion gear teeth will equal the ratio.
To Differential Questions
