x-brace on a 92
Old Feb 15, 2007 | 04:08 PM
Powersmokin's Avatar
Powersmokin
Default x-brace on a 92
I am going to be putting an x-brace on my car would like to here from some others that have installed them befor to get some tips on how to do it.thanks
Old Feb 15, 2007 | 05:44 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
If you're speaking of an aftermarket one such as the one from R-D Racing, it's not at all difficult. The front mounting holes should be there, even on a coupe and the rear ones are easy to locate, drill and install the nutserts in, if you follow their directions which are clear and precise. I don't think it took me long at all to do the initial installation, maybe an hour or so.
Old Feb 15, 2007 | 11:02 PM
SJW's Avatar
SJW
Do I correctly understand that you installed the R-D cross-frame, Chris? If so, what's your opinion of it now that you've had it in there for a while? I was checking it out on their website just today, thinking one of them might eventually end up on the LT4 I just bought from Bill...
TIA.
Be well,
SJW
Old Feb 15, 2007 | 11:12 PM
Corvette Kid
TIA.
Be well,
SJW
It makes it a whole different car from the standpoint of rigidity. Mine's off right now and I miss it. When it goes back on it will be welded solid in the middle plus a couple of other little changes. Just don't ask me how it affects the car with the top out because I don't remove my top. The last time it was out was to install the roll bar over a year ago.
Old Feb 16, 2007 | 01:05 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
I have the ST Frame, Camber, Targa Truss brace, and gas pedal and anything you buy from R D racing is top quality.
I was looking into the X Brace, but I was concerned of ground clearance as mine is lowered. Any loss on clearance?
Old Feb 16, 2007 | 01:56 AM
Trog's Avatar
Trog
I have a factory x-brace grafted onto my coupe & yes, you loose some ground clearance. But it IS worth it!
Old Feb 16, 2007 | 08:08 AM
PDQUIK95's Avatar
PDQUIK95
From: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
Hey, my first post.
Powersmokin ,I purchased a new R-D crossframe for my 95 a year ago with plans to install following my 396 stroker engine build and install, but after track testing the car, it appears I am going to need a 5 point rollbar to be legal so this will satisfy my frame rigidity in lieu of the cross frame. Plus i am going to lower the car with coilovers making the crossframe a possible problem. So if you haven't bought one yet, I can make you a good deal on mine. PM me if interested. Oh, I will also be at the CC at Richmond on the 24th in case your going and would like to see the new crossframe. I could bring it. I will be listing it in the forum FS section next week.
Rick
Old Feb 16, 2007 | 08:13 AM
Z07coupe's Avatar
Z07coupe
Just want to mention. Dave told me that some 3" exhaust systems require a dent in the bars to prevenet rubbing. I don't have an x brace, so I don't know first hand. When ordering from R & D, ask the question.
Old Feb 16, 2007 | 10:25 AM
SJW's Avatar
SJW
Originally Posted by PDQUIK95
Hey, my first post.
Rick
I don't want to jump in front of Powersmokin, but if he doesn't get in touch about buying your crossframe, I'd be interested in talking with you about it.
Be well,
SJW
Old Feb 16, 2007 | 10:26 AM
SJW's Avatar
SJW
Thanks for the reply, Chris. I'd be interested in hearing more about the additional changes you're contemplating for yours.
Be well,
SJW
Old Feb 16, 2007 | 10:27 AM
SJW's Avatar
SJW
Thanks for the heads-up about this. Good to know...
Be well,
SJW
Old Feb 20, 2007 | 04:39 PM
Powersmokin
thanks for all the info I have the r-d x-brace allready so I dont need it thanks.
Old Feb 20, 2007 | 05:39 PM
Corvette Kid
Be well,
SJW
Besides welding the center solid, boxing the the sides where they're not already boxed and modifying the two rear attaching brackets for additional clearance. This is the only place I ever scraped mine and I don't really understand why they made it the way they did back there. It's my only complaint on an otherwise excellent product. But no big deal while I'm welding on it anyway. IMO, there's no reason to not weld it into one piece once it's fitted to the car and has been used enough to take a "set." It's no more difficult to remove and reinstall in one piece. I simply ran a couple of #14 self-tapping screws into the bottom of the crossover area and then unbolted it from the car. Ready to weld solid.
To x-brace on a 92
