Derale trans pan ,ground clearance?
Old Feb 16, 2007 | 06:35 AM
SK.LT1's Avatar
SK.LT1
Default Derale trans pan ,ground clearance?
I recently obtained a Derale transmission pan for my `96 coupe,and I was curious to know if anyone else using one of these pans has expieriencd any ground clearance problems.
Old Feb 16, 2007 | 07:41 AM
Pete K's Avatar
Pete K
I have been using one since about 1992 with no issues.
Old Feb 16, 2007 | 04:13 PM
SK.LT1's Avatar
SK.LT1
Thank you for the info.Actually it was one of your previousposts that convinced me to go this route.
Old Feb 16, 2007 | 04:17 PM
Pete K's Avatar
Pete K
I like to use stamped steel pans on a street car. If you do bump it on a speed bump, or something similar, it will dent. Cast aluminum pans are a great way to go, but I have seen a few crack open when hit hard enough.
The Derale is my favorite stamped pan. Derale should toss me a few bucks for promoting them so well.
Old Feb 16, 2007 | 08:20 PM
vetster86's Avatar
vetster86
If you own a vert you will have to modify the x-brace. You would hit your oil pan before hitting the Derale pan.
Old Feb 17, 2007 | 10:06 AM
BerniesVette's Avatar
BerniesVette
My Derale pan is about 1 1/2 inches lower than the stock one. It poses no problems for me and I am getting ready to install a Kevco 7 qt. oil pan. My clearance is about the same as I had with my C3 with the larger oil pan, but I do avoid speed bumps.
Bernie
Old Feb 17, 2007 | 11:24 AM
Vic'89's Avatar
Vic'89
Anyone have a part number for this pan ?
Does it have a drain plug ?
Vic
Old Feb 17, 2007 | 11:27 AM
Pete K's Avatar
Pete K
The pans come unpainted. Because of this, I tear them out of the box, paint the pan, hang it on the wall and toss the box. I do not have the part number handy. It does have a drain plug. Nice piece.
Old Feb 17, 2007 | 11:36 AM
Pete K's Avatar
Pete K
14104 is the part number.
To Derale trans pan ,ground clearance?
