ABS, ASR Help Needed
Old Feb 16, 2007 | 09:19 AM
jrod954's Avatar
jrod954
Default ABS, ASR Help Needed
I have a 1993 vette and recently when applying the brakes the Service ABS light, Service ASR light and Brake lights up. They will go out if I shut the car off and start up again. The brake light will go out immediately, but the ASR and ABS service lights remain on until I shut off the ignition. I checked for any trouble codes when they appear but nothing registered. Anyone have ideas what I should check and/or replace? Are there wheel sensors that need to be tighted/adjusted/cleaned? Thanks!
Old Feb 16, 2007 | 11:31 AM
BlackbirdZ07's Avatar
BlackbirdZ07
Low brake fluid can cause this. Make sure the brake fluid reservoir is filled up to the mark.
Old Feb 16, 2007 | 12:35 PM
kalister1's Avatar
kalister1
My 93 (It's A Ruby) has lit up twice, I added some brake fluid and have not seen it since. I have just flushed out the fluid but have not had a chance to drive it since, too much ice on the roads around here.
Old Feb 16, 2007 | 01:05 PM
jrod954's Avatar
jrod954
Thanks guys! I will check the level and get back with you...
Old Feb 16, 2007 | 06:31 PM
jrod954's Avatar
jrod954
Thanks guys! That was it... my brake level was low. Added some more and ready to go!
Old Feb 16, 2007 | 06:33 PM
BlackbirdZ07
Excellent... Don't you love a simple fix?
To ABS, ASR Help Needed
