LT4 ED timing gear problems
Old Feb 17, 2007 | 05:15 PM
Timz06's Avatar
Timz06
Default LT4 ED timing gear problems
Last year I put an extreme duty timing kit in my lt1 motor I use on my track car. After about 2k miles I had problems, low power on track. Just recently tore the motor down, all kinds of metal in the motor, and two spun main bearings.
Just received a new 383 short block, and was getting ready to put on my ed timing set and noticed a lot of wear on the cam gear that drives the water pump. I am very surprised at the amount of wear with this amount of use. Searching around I see I am not alone.
http://forums.corvetteforum.com/show...1163505&page=3
What are the options? I would like to go with an electric water pump, but am not sure it would keep up with track duty. Any ideas (needs to run up 7k rpm)
I bought this kit from jegs. Has anyone had any luck getting a replacement set? It looks like to me, the cam gear is simply too soft.
Gear comparison. Installed LT4 ed, stock LT1
Wear
Old Feb 17, 2007 | 06:00 PM
bobmic93's Avatar
bobmic93
Last year when I needed to upgrade after h/c swap I needed to upgrade to the hd chain and after some research I learned some people had problems with it , supposedly do to soft metal. Weather theres any truth to it I just decided to go with a LT4 chain set. So far so good. Do your research!
Old Feb 17, 2007 | 07:24 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I understand your concern re/ an EWP as I've read of others who said it could be marginal in such situations. Are you using a factory or aftermarket radiator? I assume you're making rather substantial power if you're twisting it to 7K. I still have to think that with adequate cooling mods for both coolant and oil, attention to evactuating underhood heat, etc. that there must be a suitable EWP out there somewhere that could do the job. Obviously I don't have your experience in using a Corvette for this purpose. But my gut tells me that there's got to be a way.
Old Feb 17, 2007 | 08:54 PM
Dr. Evil's Avatar
Dr. Evil
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
I see no reason a EWP wouldnt work. Just do a quick comparison on the GPM ratings. I think mezeire has a high capacity one for the LT1.
FWIW, I twist my LT4 to 6700(current rev limiter) on a regular basis with the stock gears/chain. I swapped in the hotcam a couple years ago. No problems so far. Mines more pleasure/autox/occasional track day than a dedicated track car.
Old Feb 17, 2007 | 11:12 PM
Timz06's Avatar
Timz06
Just the buzz I have heard from the track guys, ewp is good for drag racing, not so good for road course...I just do de's not real racing, but figure about 20 minutes full bore on average..
This car was a stock lt1 with lloyd elliot heads and cam...400 rwhp. That engine went south. (Now i am thinking metal from the timing gears didn't help too much)
I just got a new 383 from golen, nice piece, maxed out, splayed billet mains etc. I want the capability to run this motor at 7k all day. Not just for max power, but shifting to 5th on a straight will kill your lap times..
Spent too much money on this short block to take any chances.
Tim
Old Feb 18, 2007 | 11:23 AM
RichS's Avatar
RichS
Had the same problem last year. I reused the same timing set but with a elect wp.
Old Feb 18, 2007 | 01:05 PM
STL94LT1's Avatar
STL94LT1
Contact Jim "96GS#007" Mason, his car has seen alot of track time running an EWP.
Old Feb 18, 2007 | 05:33 PM
Louis Bartay's Avatar
Louis Bartay
If you are using a EWP why not go to a Double row roller chain set(Cloyce) as you will not need the second set of teeth on the cam gear for the water pump?
Old Feb 18, 2007 | 06:22 PM
RichS's Avatar
RichS
I didn't have time to send the computer out and have the crank sensor tunned out. So I just removed the wp drive. There was nothing else wrong with the timing set to not reuse it.
Old Feb 18, 2007 | 07:14 PM
Louis Bartay
Forgot about the sensor and as expensive as the Cloyce chain and gear set is smart move.
Old Feb 18, 2007 | 11:38 PM
Klaus-96's Avatar
Klaus-96
2019 Z06 2LZ A8 Coupe
Default Comp Cams 3207 Timing Set?
As I am collecting the parts to do a head and cam swap on my 96 LT1 this is very troubling. It appears that the only alternative LT1-type timing set that hasn't been tested for the proper hardness / heat treatment is the Comp Cams 3207.
Old Feb 19, 2007 | 12:22 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Can you heat treat metals more than once? Can you get the metals of the gears to be the same via heat treating?
Old Feb 19, 2007 | 02:06 AM
STL94LT1's Avatar
STL94LT1
The Cloyes double roller timing set is ~$80, that's expensive?
Old Feb 19, 2007 | 12:45 PM
sothpaw2's Avatar
sothpaw2
I haven't heard of this Comp Cams 3207 set. If you send it to me, I can probably have it hardness tested (this is non-destructive--it will not hurt the gear) for you.
You are right to be troubled--best thing is to return the parts & don't mod the LT1!!! I guess that's not true if you are a drag racer or it's a street only car and you keep it cool. But if you live in Florida and you get the motor hot, you can't use the ED set--one of the guys on here had it fail in that circumstance. Road racing is a killer--high oil temps.
Old Feb 19, 2007 | 12:50 PM
sothpaw2's Avatar
sothpaw2
Good luck to you, Bob. The LT4 gear I tested was also soft, but I haven't heard of much buzz on that. If you had the ED, I would say that you will be fine if you don't get the oil temperture hot. If you road race wit the ED for 1 weekend even in 75 deg temp. at a serious track like Pocano or VIR or the Glen--forget it.
As for truth--if you want I can send you my ED cam gear with no teeth and you can have a look for yourself.
Old Feb 19, 2007 | 12:51 PM
Klaus-96's Avatar
Klaus-96
Thanks for the offer. I *might* just take you up on that if I can convince myself to spend $500 on the Comp Cams set!
Old Feb 19, 2007 | 12:56 PM
sothpaw2's Avatar
sothpaw2
Tim
Hi Tim,
I sent you a PM also.
If I was you, I would get some insurance from LaurelDE and continue to track your Z06.
As mentioned here, Jim Mason is the expert, and the only one I know of anywhere that has experience tracking the LT1/4 with an electric water pump. He as extensive coolers on his car to help. It can be done, and he is a great guy, he will help with info. But it is a lot of extra work--not sure if you want to do that to the Camaro or what your mechanical skill level is.
If you must track your Camaro, the reliable timing set choices that I know of are : 1) electric pump + whatever roller you want 2) Stock LT1
To LT4 ED timing gear problems
Old Feb 19, 2007 | 01:03 PM
sothpaw2's Avatar
sothpaw2
Absolutely, yes, Steve. And I strongly considered trying it. You have to know what you are doing though, and have a heat treat place do it. Usually, these things are flame-hardened locally in the teeth, and that is a very specialized process and I wouldn't know where to go for that.
In the end, I didn't purse this option because it is likely to be very expensive and why should I fix Cloyes' gear for them? If the quench is not done right, and if you just heat treat the whole gear through (instead of flame hardening) you could end up warping the part.
It's $300 a pop if you get the process wrong, how much do you want to try it?
Old Feb 19, 2007 | 01:35 PM
steve40th's Avatar
steve40th
I know where I can get it done if necessary.
But being it is I am street driver and an occasional auto crosser, I dont think I have to worry to much about my ED timing chain.
But, I will be taking th emotor out soon, and putting a EWP in, new chain and different rings (regular tension isntead of low tension oil cunsumption ring). It will be interesting to see the chains gears.
Old Feb 19, 2007 | 01:58 PM
sothpaw2's Avatar
sothpaw2
Steve,
You don't road race but you do live in Hawaii--I bet it gets kinda hot out there--the useful life of the ED will depend on how often you get your motor really hot in traffic jams, and if you auto-x it on hot days.
If you keep your oil temp lower than say <210 F>, I bet the ED will last you a long time for your usage, and I wouldn't worry about heat treating it. My LT1 was really cool with a 160 stat, new GM radiator, and fans on early by programming the chip. It shouldn't be too hard for you to keep well below 210 all the time.
