" high performance water pump"
Yes, at idle an electric water pump should be less efficient than a mechanical, but as the rpm's increase, the electrical becomes more efficient, that's why the show an increase in RWHP. They are more running more efficiently and freeing up power to go to the wheels.
An electric water pump is designed to turn at X rate, and the electric motor is designed to be most efficient for that one task. A mechanical water pump has to be able to move sufficient water from idle all the way to redline, so as the rpm increase its going to turn faster, and that isn't always the most efficient thing.
If you look at the diesel electric locomotives, they are similar to our situation with the electric water pump. The diesel motor runs at X rpm, and is built to run at that one rpm and that one rpm only. They can easily design it to be more efficient, because it just has to do one task, instead of having to be able to idle and go all the way to red line. The electric motor on the locomotive runs directly off the generator. Those locomotives are very very efficient because of this.
Just because you add more steps in the process, doesn't mean the overall system has to be less efficient.
The biggest deterrent is the lack of the heater hose provision, if you plan on retaining the heater
The C4 is a "bottom breather" in that cooling air enters the radiator from under the front of the car and passes through the cooling fins. If the radiator has dirt and debris in it (between the tubes or junk sitting in front of the fins) the radiator will not do a good job of cooling. If the tubes are clogged from poor maintenance, that makes cooling that much more difficult to accomplish.
Over years of use, the cooling tubes in the radiator become very thin due to the friction of the coolant flowing through them. Once the metal tubes get too thin, they lose their ability to effectively transfer heat. By the same token, if the fins have been bent from years of debris hitting them (even though they are behind the A/C condensor) air cannot easily pass around and thru the tubes.
No amount of cooling system pressure or the amount of coolant moved by a high-flow or super gee-whiz performance water pump is going to increase the ability of a worn out or clogged radiator to keep coolant temps down.
The trick to effective C4 cooling is to have a radiator that has no dirt or debris around the tubes and fins, a good thermostat that open properly and does not otherwise restrict coolant flow, a pressure cap of the correct rating, and good coolant in the proper ratio.
You can turn the fans on earlier, use a lower temp thermostat, add Water Wetter or other products, but if the rest of the system is not in good shape so that the pieces can do their job, you will only put off trouble for awhile.
I'm just one of those guys that would like both...
It will use more power than the standard pump at idle, but in return it will give you increased cooling at idle.
how are ya!
yep i have a 3 piece under drive pulley kit,a/c is removed,pollution pump removed,e.g.r gone too!
from what iv read some of these aftermarket water pumps can help a little as thet have higer speed integeral roller bearings,better propeller design as well for flow and reduced drag also!!
not as good as electic set up but most likely better than stock standard one though!
thanks
cheers
glen
how are ya!
thanks
cheers
glen
John
The L98 Vette pump is near enough in lenght to a std long pump BUT for Vette's only it is reverse rotation.
What ever brand you buy , make sure it is for a Vette.
If you were doing away with the serp belt drive altogether and using V belts, a std long pump would work
Bernie
