MAF screen
Old Feb 18, 2007 | 09:36 PM
black panther's Avatar
black panther
Default MAF screen
I herd that if you remove the screen in the MAF sensor you can improve air flow I also herd that this is a myth and you can actually disrupt airflow by removing this screen, I have a 86' and was wondering what the better option is
Old Feb 18, 2007 | 09:45 PM
86PACER's Avatar
86PACER
It does not hurt anything but you also won't feel a noticable difference in performance. Contrary to popular belief, the screens are there to help straighten the incoming air and not to keep debris out. That's what the air filter is for.
Old Feb 18, 2007 | 10:14 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Though I have dont that "mod", there is no real benefit untill your engine is building close to 400chp.
Old Feb 20, 2007 | 01:52 AM
RRT vette's Avatar
RRT vette
I will suggest to leave the screens in.
Old Feb 20, 2007 | 08:52 AM
thumper823's Avatar
thumper823
also to make the air flow straighter so the MAF sensor will get a accurate reading
Old Feb 20, 2007 | 08:54 AM
Kool88vette's Avatar
Kool88vette
Your running a 383. Removing the screens will increase air flow. Are you running a stock intake?
Old Feb 20, 2007 | 11:44 AM
GeosFun's Avatar
GeosFun
I have done it both ways. If there is a benefit, it is miniscule. Currently, my screens are in and I will leave it that way. In TPIS' Insider's Hints, they measured a small increase in airflow with them removed.
The hard thing with FI is there are few, if any, easy big steps in making more HP
Old Feb 20, 2007 | 12:41 PM
Steel Breeze's Avatar
Steel Breeze
Descreened MAF = 78 CFM...
Old Feb 21, 2007 | 10:15 AM
black panther
yes im running the stock TPI but I would like to swap it out any suggestions
Old Feb 21, 2007 | 11:10 AM
Aardwolf's Avatar
Aardwolf
Super ram!
Old Feb 21, 2007 | 12:49 PM
All2kool's Avatar
All2kool
My .02 cents worth is that if you must remove a screen, removing the front one only would be best.
Old Feb 21, 2007 | 01:25 PM
Aardwolf's Avatar
Aardwolf
What would that do?
Old Feb 21, 2007 | 03:35 PM
Kool88vette
I like the Super Ram. There are other intakes out there. Also, you can port out your stock plenum and get ASM runners. It would look stock but increase performance. You should get a 52MM TB. Then you should look at the exhaust.
To MAF screen
