Help with suspension--Long
Every thing else is brand new...I put the car up on jack stands, and checked the play in the wheels...at 12 and six it's tight as a drum...no play, and at 3 and nine, the same....tight and no play. Tried to turn the half-shafts in Park, and no go...both sides tight. Put it in drive, and turned the wheels by had, and no noise at all. So I start it up, put in Drive, and rev the engine, hoping to find the culprit, but it's quiet as a mouse!!??. Take it off the jack stands, back it out, and all's good, drop it in drive, and start to ease down the street, and BANG!BANG!BANG! WTF!! Help me out here guys, what could this be?? only happens when the car is on the ground, and only when it's moving forward.....don't want to drive it, for fear of tearing something up, but I don't have a clue
Cheers,
Michael
Sounds like something is hitting only when the suspension is compressed.
Are all the ujoint strap bolts tight? Are the T-50 wheel bearing flange bolts tight?
Whatever is hitting, you should be able to find some shiny spots now. Start taking it back apart.
Sounds literally like someone hitting the side of your head with a nail gun.
