Time for a NEW VETTE!!!
Old Feb 19, 2007 | 09:40 PM
A BirdMan Converted's Avatar
A BirdMan Converted
Default Time for a NEW VETTE!!!
Well... Newly Refurbished vette atleast...
Had my 96 LT4 Collector Ed. for 2 years now and i finally have the money and hookups to rebuild her to an all out performance street legal race car.
Heres my parts list so far...
This doesnot include any work done in the past two years and this is all top notch stuff going on
Rear Spring Bolts - Grade 8 - 12"
RED - BALL JOINT DUST BOOT SET
RED - DIFFERENTIAL CARRIER BUSHING SET
RED - FRONT END CONTROL ARM BUSHING SET
RED - FRONT END LINKS
RED - FRONT SWAY BAR BUSHING SET - 26mm
RED - FRONT UPPER BUMP STOP SET
RED - RACK AND PINION BUSHING SET
RED - REAR END SWAY BAR LINK BUSHINGS
RED - REAR SPRING CUSHIONS
RED - REAR STRUT ROD BUSHING SET
RED - REAR SWAY BAR BUSHING SET - 24mm
RED - TIE ROD BOOTS
Metal Strip cust. bracket shift light
Black permatech gasket sealant
Crank Seal
Dexcool Coolant
Intake Manifold Gasket Set
Blue LED Fuel pump Cutoff switch
Red LED Shift Light Cutoff switch
Oil Pan Gasket
R134a Refrigerent
Rear Main Oil Seal
Spark Plugs
Timing cover gasket
Timing cover seals
Valve Cover Gasket set
Water Pmp Gaskets
BFG T/A DR1
Bilstein Moraca Valving Shock Spec Rebuild Front
Bilstein Moraca Valving Shock Spec Rebuild Rear
Driver Fender Flare
Passenger Fender Flare
OBD2 LT1/LT4 Edit
17x11 Chrome ZR1 +50mm rear
ET Open Ended Lug Nuts
Tie Rods Front
Tie Rods Rear
Console Shift Plate (M/T)
CC Pushrods
Cltuch Slave Cyl
Timing chain
Forged Aluminum .50" Spacers Pair
4.10 Rear End Gear Swap
CC 07-467-8 230/236 Camshaft
adj. pushrod length checker
Copper Collector Gaskets 3"
Copper Header Gaskets
CC Hyd. Roller Lifters
CC Locaters
Mcleod Twin Disk Clutch & SMF
Meziere HD Elect. Water Pump
CC Retainers
CC Valve Locks
CC Valve Seals
CC Beehive Valve Springs
2.5" ARP Hardened Wheel Studs Front
2.5" ARP Hardened Wheel Studs Rear
Pill Kit 6000-6800
Shift Light
Opti Spark
CAGS Bypass
Console Lid Repair Kit
Front Lower Spoiler 3pc
Header Molding
Lower Front Ball Joints
Pass Seat Track Exchange
Rear Bose Emblem Speaker Cover
Rear Wheel Bearings
Shifter Boot MT
U Joints Driveshaft
U Joints Half Shaft
Weatherstriping Kit
Crank position sensor seal
Headliner
Recover Both Visors
Custom 4pt Rollbar
New Carpet set
-Kevin
Rebuild looks like will commence in 2 1/2 weeks after the last few parts arrive.... approx 150 act. hours to be completed over two weeks. Then comes the custom paint job: Collector Edition Silver... Grandsport Style.
I will keep you posted with the progress & pics... and videos after motor rebuild
I CANT WAIT!
Old Feb 19, 2007 | 09:46 PM
STL94LT1's Avatar
STL94LT1
Looks like you have alot of work ahead of you!!!
Old Feb 19, 2007 | 10:09 PM
sami85L98's Avatar
sami85L98
Thats a lot a parts and lot a work, u said pill kit 6-6800 are u using MSD or compatible ignition box? and 4 pt roll cage : u just wanna use this to stiffen chasis or according to NHRA rukes ?. and i did not see any Head work or aftermarket heads and if u r using untouched original heads with that Camshaft i think it would be overkill on a stock heads, Remember Heads are more imp than camshaft.
Good luck man,
Old Feb 19, 2007 | 10:11 PM
bogus's Avatar
bogus
good luck! I expect it will be done by the end of March. These things take twice as long as estimated... then double that.
Old Feb 19, 2007 | 10:25 PM
MikeC4's Avatar
MikeC4
Other than the "Rear Bose Emblem Speaker Cover", everything else looks like a piece of cake!
good luck...lot's to do there
Old Feb 19, 2007 | 11:04 PM
A BirdMan Converted
Good luck man,
Autometer Shift light with built in module, will run a 6200 pill on a 6500 redline, Carputing LLC is going to be my tuning program.
i considered heads but dont have room in current budget- CNC Portjob on heads and intake would run about 1200 but then i would feel obligated to replace all of the internal bearings since i would have removed the heads, my friend with a 96 formula and 02 650+hp TwinTurbo Firehawk, said it would be a PITA to get get everything re-lined up if i untorqued the heads. I dont want to drop 2+ on AFR and i want everything motor wise to be "undoable" (even though i never will). I want the gains but not the headaches so ive decided stock heads for now. Ive already got a running total of about 10 in parts and i am getting the labor basically for nothing by my friends/coworkers at our vette dealership so im at my limit.
In about 2 years when the payments are done im redoing her with a supered' forged 383, i just want something fairly powerful i cant get used before the 383.
My exhaust should make up partially for the stock heads, she's abit too free flowing now but will leave room for growing. now LT's, no cats, 3" FULL MANDRELS through 3" X to 3" I/O Flowmasters.- Loudest and best sounding Ive ever heard! I will post a vid soon
-Kevin
Old Feb 19, 2007 | 11:16 PM
A BirdMan Converted
...and 4 pt roll cage : u just wanna use this to stiffen chasis or according to NHRA rukes ?....
NCCC AutoX Group III Req.s- and custom 4pt because im going with the front facing sidebars with the standard roll bar rather than the rear two supports that will restrict me from storing the targa top in the back
Old Feb 19, 2007 | 11:21 PM
A BirdMan Converted
http://www.zippyvideos.com/9411544566678396/mvi_4021/
Darn upload Distortion makes it have a whirly sound to it... that sucks, i have gotten SOOOO many compliments in person.
Old Feb 19, 2007 | 11:27 PM
A BirdMan Converted
Originally Posted by A BirdMan Converted
... Then comes the custom paint job: Collector Edition Silver... Grandsport Style....
Red Powdercoated J55 GS Calipers with New Sebring Silver with a Satin Black GS Stripe, Red hasmarks and Matching silver GM Fender Flares with GM Style deep centered 11" chrome ZR1's
Finsihed with new tint and a Professional SGR AutoX Vinyl letter Job.
SGR Is the site currently being built in dedication to my Collector Ed.
-Kevin
Old Feb 19, 2007 | 11:29 PM
sami85L98's Avatar
sami85L98
make sense to me, again good luck as bogus said double the time,
To Time for a NEW VETTE!!!
