Sway Bar Diameter and Bushing Question
Old Feb 20, 2007 | 10:08 AM
smearig's Avatar
smearig
Default Sway Bar Diameter and Bushing Question
I measured the sway bars on my '84 last night and the front was 24.7 to 24.9 mm in diameter. All of the sites like Ecklers and VBandP list bushing kits for 24 mm and 26 mm sway bars. Are they usually nearly a mm larger than the size of bushings you are supposed to order?
Old Feb 20, 2007 | 10:51 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Did you measure the diameter and divide by 3.14? Or use calipers?
Anyways I think 25mm was a Z51 size in 84 only.
Old Feb 20, 2007 | 11:08 AM
smearig's Avatar
smearig
I measured with digital calipers in about 10 different places. It's not a Z51 car, but there's no guarantee I have the original sway bar. I'm guessing the 24mm bushings would be a better choice than the 26mm right? I have not seen a 25mm front bushing in my searching around.
Old Feb 20, 2007 | 11:09 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Linky http://corvetteactioncenter.com/tech/c4/susp_chart.html
Old Feb 20, 2007 | 11:14 AM
CentralCoaster
It's probably a 24mm then. I would just buy those, they'll fit.
Measure it where the stock bushings go. The swaybar is smoothed out and a little smaller here.
Old Feb 20, 2007 | 11:38 AM
smearig's Avatar
smearig
Originally Posted by JrRifleCoach
Interesting, my rear sway bar is about 23.8 mm in dia. Maybe I have a Z51 and didn't know it.
It was 24.7 where the bushings wore the coating off, 24.9 most other places.
Old Feb 20, 2007 | 11:47 AM
JrRifleCoach
Its either a 24mm or a 25mm
Look at your RPO codes for Z51 or you could try to run the steering wheel lock to lock. 2.0 turns is a Z51.
This assumes that a previous owner hasn't changed the bars.
Old Feb 20, 2007 | 11:53 AM
smearig's Avatar
smearig
Coincidentally I have the rack sitting on the floor of my garage right now. It's a 242k mile 5+ owner car so nothing would really surprise me at this point.
Old Feb 20, 2007 | 03:23 PM
CentralCoaster
That's even easier. Use a crescent wrench to turn the rack lock to lock.
2 turns (z51) or 2-1/3 turns. Or just tell me what 2 letter code is on the dust cap.
Old Feb 20, 2007 | 03:31 PM
smearig's Avatar
smearig
I'll check when I get home tonight. Good thing I already bought a 2.5 turn rack because I believed the PO when he said it wasn't a Z51.
Old Feb 20, 2007 | 03:33 PM
CentralCoaster
Take it back, they won't know any different. I bought a rack that had all the z51 part numbers and it still was the wrong rack.
Old Feb 20, 2007 | 03:48 PM
smearig's Avatar
smearig
I ordered mine so I'd probably have to take the shipping hit to send the 2.5 rack back and have the 2.0 rack sent.
Old Feb 21, 2007 | 09:53 AM
smearig's Avatar
smearig
It's a Z51, the rack I took out is definitely 2 turns lock to lock. Do you guys think it's worth the hassle of getting the quick ratio rack or will I even notice the difference?
Old Feb 21, 2007 | 10:02 AM
CentralCoaster
You will notice the difference and regret it if you do any sort of performance driving.
Old Feb 21, 2007 | 10:14 AM
smearig's Avatar
smearig
Thanks for the advice, I'm going to send that base suspension rack back tonight. I still need to order a p/s pump anyway so I'll just order them both at the same time.
To Sway Bar Diameter and Bushing Question
