Geometry Lesson, C4 rear spring?
Old Feb 21, 2007 | 02:06 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Default Geometry Lesson, C4 rear spring?
Okay, I am having a geometry problem here. I look at how the rear leaf spring is located in the rear, and how the lowering/raising spring bolts are put in.But how does the spring actually hold the car up? It is bolted to the center, and the spring angles down to the ground. The spring bolt goes through it with a pad towards the ground, and one on top of the spindle.
It seems all it does is push the center up. I am at a loss, like its staring me in the eyes and I cant see the obvious.
Old Feb 21, 2007 | 03:16 AM
Cyclonite's Avatar
Cyclonite
Default Geometry
It pushes up in the center (to the body) and down on the ends (to the wheels). The first time I saw it I was like "What the hell?". But it's a pretty easy setup. A floor jack with a pad to protect the spring can be used to take pressure off the wheel end to disconnect it.
T
Old Feb 21, 2007 | 05:36 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Yeah Steve its bolted hard to the rear cover of the diff, which cant move in the car. The ends of the spring are pulling down on the rear knuckles which holds the car up. Pulling the knuckles down will raise the car up
As apposed to the front end, the spring is held under the engine cradle and pushes down against the lower control arms.
Old Feb 21, 2007 | 10:39 AM
steve40th's Avatar
steve40th
Thanks, It just seems upside down. Thats why arent and Engineer!!
Old Feb 21, 2007 | 03:03 PM
SJW's Avatar
SJW
Think of it this way:
The spring pushes the wheels away from the chassis.
Be well,
SJW
Old Feb 21, 2007 | 04:52 PM
C4Techie's Avatar
C4Techie
Haven't you ever pulled yourself up by the boot straps? It's the same principle.
Old Feb 21, 2007 | 05:25 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Oddly enough, the same basic spring configuration was the norm on most autos until after WWII. The only real difference was that the cars had live axles instead of independent control of each wheel. Although it works pretty well on Corvettes, on which it's used since '63 and at least through the C4 era (not sure after that), I still think it's rather archaic and can certainly be improved upon.
Old Feb 21, 2007 | 11:25 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
, but you cant argue with results...
Old Feb 22, 2007 | 12:10 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Originally Posted by steve40th
........ like its staring me in the eyes and I cant see the obvious.
Your killing me.....
Old Feb 22, 2007 | 08:49 AM
SJW's Avatar
SJW
And on most horse-drawn carriages before that...
I'm curious as to why you feel this way. The transverse leaf setup has many clear advantages, and works extremely well. Obviously, a solid axle with dual parallel leaf springs leaves a bit to be desired, but with fully-independent suspension, what don't you like about it?
Be well,
SJW
Old Feb 22, 2007 | 09:39 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
That spring is where the ET is at for your 60' times.
To Geometry Lesson, C4 rear spring?
