Dana 44 Types
Old Feb 21, 2007 | 06:06 PM
elkabong's Avatar
elkabong
Default Dana 44 Types
I just picked up my D44 and I am trying to determine what year it came from. I have searched every where but no info. There are two numbers the top one is 43115 and the bottom is 14105120. Is there some where I can look up what year this came out of?
Old Feb 21, 2007 | 07:11 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
As a starting point, what ratio is it? (assuming stock gears) Also, what size are the holes where the camber brackets bolt on?
Old Feb 22, 2007 | 07:51 AM
elkabong's Avatar
elkabong
The gear is 3.45 and the holes are 0.50". Also, how many teeth should be on the ring and pinion. I would like to validate it is the correct ratio before I install it.
Old Feb 22, 2007 | 02:41 PM
C4Techie's Avatar
C4Techie
There should also be another number, starting with a "6". Like "605491 X ". Is there a specific reason you need to know the year? The ratio is determined by dividing the number of ring gear teeth by the number of pinion teeth. The tooth counts should be stamped on each of the gears, such as 38 11 (38 tooth ring gear and an 11 tooth pinion).
Old Feb 22, 2007 | 04:32 PM
Snakecharmer383's Avatar
Snakecharmer383
How much did you pay for it, just curious?? I hear they are getting few and far between these days?
Old Feb 22, 2007 | 08:03 PM
elkabong's Avatar
elkabong
C4Techie - I will try to find the other number. The numbers I posted were located on the housing of the carrier/batwing.
Snakecharmer383 - PM sent.
Old Feb 22, 2007 | 08:12 PM
Bob CTS's Avatar
Bob CTS
To get the best result remove the batwing and the numbers for the ratio will be stamped on the gear as mentioned above divide one into the other, I also believe there will be a date stamp as well, do not qoute me on that.
Bob
Old Feb 22, 2007 | 08:49 PM
C4Techie's Avatar
C4Techie
The other number should be stamped into the bottom of the carrier assembly. There should be a GM number like the one you provided, a date, and either the ratio or the tooth counts of the ring gear and the pinion. Only trust the ratio numbers if you have good reason to believe that the ratio has never been changed.
Old Feb 22, 2007 | 09:27 PM
severe-1's Avatar
severe-1
Old Feb 23, 2007 | 03:03 PM
C4Techie's Avatar
C4Techie
Those are the stampings I am referring to.
Picture #1: No comment necessary. All the answers are visible. 605491 X = Dana 44
Picture #2: 605321-6 = 1988 - 1990 Corvette w/2.59:1 ratio. Dana 36
Picture #3: 41725 Ring gear goes with pinion # 41724 = Set #72719-5X. 3.07:1 (43-14) Dana 44
Old Feb 24, 2007 | 09:47 AM
elkabong's Avatar
elkabong
Cool...... thanks.
I ordered a complete bushing kit yesterday from www.p-s-t.com. I decided to go with those because they are polygraphite. My hope is to cut down on squeeks. http://www.p-s-t.com/gm/gmvet.html
Old Feb 24, 2007 | 05:05 PM
C4Techie's Avatar
C4Techie
Did any of severe-1s numbers match up with what you have?
Old Feb 25, 2007 | 09:27 AM
elkabong's Avatar
elkabong
I confirmed it is a D44 with 3.45s. I would like to know what year it came of just because. The numbers on the ring gear are 9 2190 Dana D 43626 P86142 38 11.
Old Feb 25, 2007 | 10:04 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Originally Posted by severe-1
I thought I recognized that pic
Old Feb 25, 2007 | 12:34 PM
C4Techie's Avatar
C4Techie
The numbers on the ring gear don't identify a year. I susprct it is 1992 or later. As you can see in the pictures, the date is the bottom line of the numbers stamped into the carrier.
To Dana 44 Types
