header bolt questions
Old Feb 21, 2007 | 08:31 PM
champs65's Avatar
champs65
Default header bolt questions
Couple quick questions all,
--Should I use threadlocker, or doesn't it really matter?
--Tighten from the center out, or stagger?
--How much torque? (85, iron heads)
just doublechecking, thanks!
Joe
Old Feb 21, 2007 | 08:38 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The '85 Vette FSM calls for 20 lb-ft torque but no mention of torque sequence nor use of a thread locker.
Old Feb 21, 2007 | 09:12 PM
Bob CTS's Avatar
Bob CTS
Joe,
I would think that threadlocker is no use, most threadlockers will give at high temperatures, as far as sequence I would start in the center and gradually step up to the torque in increments, like in the head torque sequence.
Old Feb 21, 2007 | 09:20 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Originally Posted by rspreng86
Joe,
That's the default procedure for most things, in lieu of instruction to the contrary. Recheck after a heat cycle and again after a few more and you should be good. I use stainless header bolts, no Loctite and have no problems with loosening.
Old Feb 21, 2007 | 11:31 PM
vader86's Avatar
vader86
Stuff like Loctite is not going to handle the temperatures of a header, it'll be of no use.
Tighten the bolts and recheck them after the first few heat cycles.
Old Feb 22, 2007 | 05:48 AM
champs65's Avatar
champs65
Thanks for the input guys. I appreciate it
Joe
To header bolt questions
