95 c4 vats resistance
Old Feb 23, 2007 | 05:38 PM
necauto's Avatar
necauto
Cruising
Default 95 c4 vats resistance
Is the resistance table I've seen posted hear for the vats valid up to 96
C4? I was thinking of using a decade box connected to the colunm connector. With trial and error, at most it will take 15 tries if that table is right. Then i'll get the right key pill resistor from the dealer. My original BCM smoked. Just want to get it running with a used BCM so i don't have to flat bed it to the dealer to get a new BCM flashed with the right miles.
Old Feb 23, 2007 | 09:38 PM
jfb's Avatar
jfb
Yep. Be aware that the resistance tolerance for each value is about 4%, so your substitution box should be measured before each trial to confirm that your next test will be valid.
Old Feb 24, 2007 | 01:17 AM
93*Corvette's Avatar
93*Corvette
Here is the chart...
To 95 c4 vats resistance
