Shocks. Get some later model FE1 Bilstein's and you will be set. I went from the FE1 to the Z51 HO and it is much stiffer over the bumps with the same spring.
are the FE1s and the z51s interchangeable..?
Second new guy question....are zr1 shocks the same a z51?
Dayum, sure wish I could get into that simple black/white world.
The reality I'm living in is much, much more complicated.
On the top of the tech/perfomance page look for the "sticky" topic that says c4 technical summary and FAC. Should help answer most of your questions. But I have one for you... how did you get your car so light!
I would immagine on a regular weight c4 changing the shocks alone would do more. In your car, being so much lighter, those springs must be part of what is making it stiff.
I'm no expert though. Someone should chime in with an exact solution for you.
I just wanted to say NICE CAR!!!.
From: One day you're a Comet...the next day you're dust... Arkansas
It is both shock AND spring. I would look for a FEI (standard) spring and match that with Bilstein HD (not Sport Z51) shocks. That should give you less stiffness when the spring is compressing and still give you good damping on rebound. BTW my Z51 does the same as nowwhat's car and I'm 6' 5" so I crack my head pretty hard sometimes!
