Jet Performance Chip vs. Hypertech Chip
Old Feb 25, 2007 | 12:23 AM
biggunz240's Avatar
biggunz240
Default Jet Performance Chip vs. Hypertech Chip
i have a 1988 C4 vette with the L98 of course... i want to install a performance chip in my vette... i am in a toss up between the hypertech chip and the jet chip.. are there any pros or cons of each of them? success or failure stories? i need some advice b/c i am ready to make the purchase... thanks everyone!
Joey O
Old Feb 25, 2007 | 12:54 AM
James93LT1's Avatar
James93LT1
Veteran: National Guard
I would recommend getting a chip from Alvin at PCM for Less.
Old Feb 25, 2007 | 12:56 AM
biggunz240's Avatar
biggunz240
tell me some more... how do i reach this guy? when has it done for you?
Old Feb 25, 2007 | 01:06 AM
James93LT1's Avatar
James93LT1
Alvin has done quite a few Forum members car with great result.
On a stock car, the performance increase will be between 5 to 15 hp, depending on the car.
But as you mod, the chip will need to be retuned to the mods, and Alvin can retune your chip at a reasonable price.
Once you do any mods, the other brands chip will become useless.
http://www.pcmforless.com/index.php?...d=45&Itemid=40
Old Feb 25, 2007 | 01:07 AM
cv67's Avatar
cv67
St. Jude Donor '05
Dont bother with the Hyper or the Jet, waste of $$
Old Feb 25, 2007 | 01:16 AM
arkangel81's Avatar
arkangel81
both chips are crap.. Alvin kicks major booty stick with him if you want a good product
Old Feb 25, 2007 | 01:39 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Old Feb 25, 2007 | 02:33 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Definately agree... Alvin did my chip also... his work outshines all the rest,,, don't waste your money on junk....
Old Feb 25, 2007 | 08:52 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Cheap, easy horsepower always sounds appealing to me, so I went to the PCMforless site.
The dyno result section looked good, especially the one for the LT4 (Camaro); nice horsepower gain there.
So, wondering how this power gain was achieved, I went to the FAQ's and got this:
What can you do for my car?
Written by PCMforless.com
For your GM vehicle we can:
Change the fan turn on temperatures for a 160° thermostat.
Program the transmission to perform similar to a shift kit (1994 and newer). and delete the dreaded Torque Management
Power program the car for use with premium octane gasoline.
Remove the top speed limiter.
Correct the speedometer and transmission for gear and tire changes.
Correct for the use of a larger throttle body.
Change idle settings and restore drivability with cam installs.
Correct for larger injectors.
Correct for larger displacement (383, 396, etc....).
Improve mileage especially on the 99 and newer trucks.
And more! Just ask if you want something done that isn't listed.
I'm still wondering how that stock LT4 Camaro got the extra 23hp....
Can anyone enlighten this clueless Vette owner?
Larry
code5coupe
Rich Millward's Avatar
Rich Millward
Default Hypertech Junk
I bought the Hypertech, and it is junk...car ran rough, shifted rough, with no noticeable gains at all....I took it out and returned it to stock chip. Much better...I would strongly advise against it...
Old Feb 25, 2007 | 01:07 PM
arkangel81's Avatar
arkangel81
wish i knew.. little timing adv. and until i know how to tune somthing i'll stick with magic..
Old Feb 25, 2007 | 01:20 PM
vader86's Avatar
vader86
both crap, nothin is worth the money unless its custom and even then its not needed until you have significant mods done
Old Feb 25, 2007 | 10:39 PM
BadjerJim's Avatar
BadjerJim
Here's the link to the post I did last November about Alvin, and PCMforLess.com:
http://forums.corvetteforum.com/show....php?t=1555467
Read my post for my "seat of the pants" impression of the chip upgrade.
This - for a bone-stock 1990.
NO - I don't do dyno, or have any real interest in seeing actual horsepower improvements. Maybe someday, when I do heads/cam/headers/intake/etc.
Side note: Again, I have no connections to PCMforLess, Alvin, etc.
They just did tremendous work for me. Reasonable price. Quick turn-around. No BS.
My 1990 is my daily driver car. I've had NO PROBLEMS at all since the install. For what it's worth, this car has 145K miles on the clock, and uses NO oil. It gives me about 17mpg around town, and 25+ on the highway.
Old Feb 27, 2007 | 01:23 AM
biggunz240's Avatar
biggunz240
thanks for all the input everyone!! i just ordered my custom PCM chip from Alvin @ PCMForLess.com this was just too easy of a choice!
To Jet Performance Chip vs. Hypertech Chip
