ecm where is it
Old Feb 25, 2007 | 05:44 PM
wmkj69's Avatar
wmkj69
Default ecm where is it
My 86 quit while driving after I hit a small bump. I asked and you people had some really helpful info. I did like you said. I turned on the key and the SES light does not come on. It points to the ECM. Well I have done as the book said. And I can't find it. I have removed the right side plastic under the dash. I have removed the front of the dash(pad), I can see the VATS box. But where is the ECM. Thanks guys!
Old Feb 25, 2007 | 05:48 PM
vader86's Avatar
vader86
The ECM is behind the dash pad, but you cannot remove it that way. If the hush panel above the footwell is removed, you will have to put your head in the footwell and look straight up. There are two large bolts holding the ECM in place, I want to say they are 10-11mm, and you will need a couple extensions.
The ECM slides down, gently tug on the harness to pull it down.
Old Feb 25, 2007 | 06:04 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
, I found that if you sit in the seat upside down, with your legs out of the roof, it is easier then trying to bend over the side of the car... but it still isnt easy.
Old Feb 25, 2007 | 11:18 PM
ozvette87's Avatar
ozvette87
Thats what i did too
Old Feb 26, 2007 | 12:58 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Considering the seat takes 5 minutes to remove, I think I'll try that instead.
To ecm where is it
