" spark plug indexing tool "
Old Feb 25, 2007 | 07:42 PM
sxyvet's Avatar
sxyvet
Default " spark plug indexing tool "
hi guys,
how are ya!
now that i brought the spak plug indexing washers kit, i saw alot of places sell the " spark plug indexing tool"!
what is the benefit of this tool?
does it help install the spark plug indexing washers easier?
from what im thinking is that you can pre install a spark plug in to this tool rather than the cylinder head and you can see which way the electrode is facing and then adjust with index washers as required.
is this about rite please?
thanks again guys!
cheers
glen
Australia
Old Feb 25, 2007 | 08:11 PM
bogus's Avatar
bogus
I suspect you can make your own... simply use a marker to note where on the plug socket the electrode is.
Old Feb 25, 2007 | 09:14 PM
106mm's Avatar
106mm
You are correct. These come in handy if it's difficult to see the plugs once they are in the heads (headers, etc.). I always just make a black stripe all of the way up the side of the plug and the socket with a Sharpie to help me see where the ground strap points. I've never owned an indexing tool.
Old Feb 25, 2007 | 11:18 PM
sxyvet's Avatar
sxyvet
hi 106mm and bogus,
how are ya!
thanks guys for your replys!
cheers
glen
Old Feb 26, 2007 | 01:01 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Old Feb 26, 2007 | 04:13 AM
sxyvet's Avatar
sxyvet
hi centralcoaster,
thanks mate for the picture of the cut back/marked plugs!
cheers
glen
Old Feb 26, 2007 | 09:55 AM
airblaine's Avatar
airblaine
Default finish the thread!
well?.......... does the electrode go up or down?
Old Feb 26, 2007 | 10:10 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
what is the benefit of this tool? glen
Australia
I have to ask the same question.
I've looked at all the tools...they seem to be nothing more than a nice piece of aluminum with a threaded hole.
What, exactly, is it supposed to do???? Not even the websites selling the tools explain how they work.....
I'm baffled.
Larry
code5coupe
Old Feb 26, 2007 | 10:43 AM
CentralCoaster
The gap points up, or more correctly, towards the intake valve. That's what I've heard anyways.
It almost makes sense to put the ground strap in front of the exhaust valve, maybe shield the electrode better from heat fouling from the exhaust valve?
Old Feb 26, 2007 | 10:56 AM
caa5030's Avatar
caa5030
What happens if you dont do this? I just put a new set in, and gapped them all correctly but I have never heard of doing this. My car is no high performance machine now, its all stock.
Old Feb 26, 2007 | 11:28 AM
rocco16's Avatar
rocco16
Nothing. Don't worry about it.
The factories don't index plugs, and 99.99999999999999% of cars on the road don't have indexed plugs.
As some who have done back-to-back testing have said, "It won't make any noticeable difference....maybe not even any measureable difference."
Larry
code5coupe
Old Feb 26, 2007 | 11:41 AM
jhammons01's Avatar
jhammons01
NEVER heard this one before..........Never.
There is no Flow issue.
Compressed Fuel source is going to have the same molecular excitement no matter where it is located in the compression chamber. Hence no matter where it is ignited.....it is just ignited. Understand the Gas and Oxygen are supposed to be mixed and almost to the point where it ignites itself. Think about a Diesel, it just compresses the mixture until it explodes under the massive compression THAT has the molecules so excited/heated they just ignite and who knows where the exact point of ignition takes place.
I'm not worried if I am completely ignorant on this subject. My interest is more piqued than anything. I'd like to hear the theory, I may learn something........which would make this a great Monday.
Old Feb 26, 2007 | 11:44 AM
glide's Avatar
glide
St. Jude Donor '13,'19
I may be new to the forum but not cars. I think a nice set of hotter burning platinums would do just as well. Just my 2 cents!
Old Feb 26, 2007 | 11:55 AM
CentralCoaster
Platinums are a performance compromise in order to gain longevity.
But you likely won't notice or measure that difference either.
Old Feb 26, 2007 | 12:09 PM
CentralCoaster
Actually that sort of stuff is very critical in IC design. Many cars now have 2 spark plugs in each cylinder, some with different advance to optimize the flame propogation to make best use of the combustion chamber.
Old Feb 26, 2007 | 12:21 PM
Aardwolf's Avatar
Aardwolf
I remember reading the ground strap should be up, or toward the ex. valve like you mention. The ground strap can make a slight flame shadow.
Old Feb 26, 2007 | 01:35 PM
jhammons01's Avatar
jhammons01
There are two Plugs on Each Rotor Housing for the RX-7. One fires after the other in this same timing issue. But I have never heard of the ground strap thingy being an issue
Not arguing, just probing. I'd like to learn more.
To " spark plug indexing tool "
Old Feb 26, 2007 | 01:54 PM
CentralCoaster
Google "spark shrouding"
I'm sure there's some relevance to it, but indexing plugs on our cars is overkill. There isn't even a consensus on which way to point them.
Old Feb 26, 2007 | 02:03 PM
nogoodsam's Avatar
nogoodsam
From NGK website....
http://www.ngksparkplugs.com/techinf...300&country=US
Indexing refers to a process whereby auxiliary washers of varying thickness are placed under the spark plug's shoulder so that when the spark plug is tightened, the gap will point in the desired direction.
However, without running an engine on a dyno, it is impossible to gauge which type of indexing works best in your engine. While most engines like the spark plug's gap open to the intake valve, there are still other combinations that make more power with the gap pointed toward the exhaust valve.
In any case, engines with indexed spark plugs will typically make only a few more horsepower, typically less than 1% of total engine output. For a 500hp engine, you'd be lucky to get 5hp. While there are exceptions, the bottom line is that without a dyno, gauging success will be difficult.
Old Feb 26, 2007 | 03:03 PM
Road Agent's Avatar
Road Agent
