comp test & leakdown results
Old Feb 25, 2007 | 09:34 PM
GS977's Avatar
GS977
Default comp test & leakdown results
i've noticed my GS is smoking under acceleration or just reving in nuetral. it looks like blue-black color. anyway today i ran a comp test and then a leakdown just to see what all 8 cylinders are doing. this is the first time i did it to this engine so i have nothing to compare it to.
how do these numbers look
(1> 210psi. 5 % leak)..... (2> 210psi. 5 % leak)
(3> 200psi. 6% leak)..... (4> 215psi. 4 % leak)
(5> 200psi. 5 %leak)..... (6> 215psi. 5 % leak)
(7> 205psi. 5 %leak)..... (8> 205psi. 3 % leak)
what would make it smoke so much, could it be the oil rings or valve seals. all the plugs were dry when i pulled them. no oil on them and they were all a light tan almost white color.
the motor is running strong accept the smoking
any ideas.
oh... the motor has @30,000 miles on it.
this is the short block i have with my lt4 heads and intake on it
http://www.sdpc2000.com/catalog/1580...e-Assembly.htm
Scoggin-Dickey
LT1 383 11.8 to 1 Flat Top Piston, Custom Short Block Engine Assembly
This custom short block engine assembly from SDPC features a race prepped LT1 block with Milodon steel splayed center main caps. It also comes with a Lunati 4340 forged crankshaft, Lunati Pro Mod 5.850 rods, SRP forged flat top pistons, JE file-fit rings, Federal mogul race bearings, and is internally balanced.
Old Feb 25, 2007 | 09:36 PM
Pete K's Avatar
Pete K
If you are running teflon oil seals on the valve guides, I would suspect them first. A leaky intake gasket could also be an issue,.
Old Feb 25, 2007 | 09:58 PM
GS977's Avatar
GS977
thank you Pete, i never even thought about the intake.
the motor was already in the car running when i bought it so i dont know what seals are in them.
how do i check for the intake leaking. or should i just remove it and change the gaskets.
Old Feb 26, 2007 | 01:31 AM
cerino2000's Avatar
cerino2000
Doesn't that thing ping like hell?
Old Feb 26, 2007 | 07:44 AM
GS977's Avatar
GS977
yes it has, but not that often. i have to be carefull where i get gas.
Old Feb 26, 2007 | 07:49 AM
Pete K's Avatar
Pete K
It may be tougher to diagnose an intake gasket than to change it. If you do pull the intake, there should be residue in the port that was leaking. Hopefully, it is only the intake gasket.
Old Feb 26, 2007 | 07:21 PM
GS977's Avatar
GS977
i'm going to change the valve stem seals and the intake gaskets and see if that helps any.
whats the best seals and gaskets for the LT4 and where is the best place to get new seals and LT4 intake gaskets.
thanks for the help
Old Feb 26, 2007 | 07:29 PM
wro87's Avatar
wro87
You might want to try the SEAFOAM trick and GM makes a spray can that you can shoot right in the PB vac hose. You might have a bunch of carbon and that might get rid of it! wro87
Old Feb 26, 2007 | 07:48 PM
GS977's Avatar
GS977
i just did the seafoam last weekend. i took the tb off and poured the seafoam in my little spraygun and sprayed all inside the intake really good then used a 3/8 fuel line and funnel to pour it in each intake port and let it sit for @ 30 min.
talk about smoke for ever!!!!!!!!
it smokes under load or full throttle
To comp test & leakdown results
