High Flow cat
Old Feb 26, 2007 | 09:59 PM
BlackVette00's Avatar
BlackVette00
Default High Flow cat
I have Several questions. Are high flow cats worth it? will any codes come on with high flow cats, and are pace headers any good?
Old Feb 26, 2007 | 11:20 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Hi flow cats thro NO codes...
Year and engine if any mods, etc helps...
Never heard of Pace headers.... TPIS, Hooker, Melrose, Heddman
Old Feb 26, 2007 | 11:22 PM
clf93lt1's Avatar
clf93lt1
pacesetter only makes shorty headers.
Old Feb 26, 2007 | 11:24 PM
BlackVette00
93 vette, 6 spd, muffler eliminator, and eliminated the resanator
Old Feb 26, 2007 | 11:35 PM
BlackVette00
would these headers fit my car?
http://www.gforce-tx.com/93-97-LT1-Cars-Exhaust.htm
Old Feb 26, 2007 | 11:53 PM
clf93lt1's Avatar
clf93lt1
that part # is for a f body
Old Feb 27, 2007 | 01:23 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
To avoid power loss due to exhaust restriction you need about 2.2cfm of flow for each hp generated, e.g. on a 300chp LT1 you need to flow 660cfm total or 330cfm on each side. But cats that will flow more than your requirements.
Old Feb 27, 2007 | 04:30 PM
BlackVette00
are these headers any good?
http://cgi.ebay.com/ebaymotors/Paces...QQcmdZViewItem
Old Feb 27, 2007 | 04:32 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
In some circumstances a low restriction exhaust with high flow cat can throw an EGR code. The EGR requires exhaust backpressure to bleed off vacuum and close.
I've never had this problem though.
You simply can't beat the Carsound cat for the price & performance. It's made by magnaflow, several ebay vendors sell them for $50-$60 for a 3", and all flow tests I've seen it flows the same as a Random Tech.
Old Feb 27, 2007 | 11:41 PM
carriker's Avatar
carriker
Shorty headers won't do much for your. Get longtubes.
Edit: won't do much for your car*.
Old Feb 28, 2007 | 04:50 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
That's the one I got with the air tube. I think it came from Performance Peddler $60. It made a noticable difference. You just have it welded on.
Old Feb 28, 2007 | 04:53 PM
Perfusion's Avatar
Perfusion
Originally Posted by BlackVette00
Although I've never owned a set, I feel fairly confident in saying, "No." I can't really recall the last time I heard anything positive said about Pacesetter products from someone who'd had them more than a year.
Old Feb 28, 2007 | 05:10 PM
SK.LT1's Avatar
SK.LT1
Well,I can`t speak from expieriance yet, but I have purchaced those headers for my `96.After visual inspection,I found them to look pretty well made.
Old Feb 28, 2007 | 05:15 PM
d48mclain's Avatar
d48mclain
Interesting theory. I dyno tested a set of CarSound cats on a car making around 330 rwhp and up to 5000 rpm there was for all practical reasons no effect. Over that there was a mild loss of power up to about 5-6 hp.
Old Feb 28, 2007 | 05:23 PM
d48mclain's Avatar
d48mclain
Been going through "header hell" lately removing a very expersive set of headers last week that had issues and reinstalling my old Hooker Super Comps.
Put the car on the dyno today to retune and very, very much to my surprise, there is a leak in one of my Hookers that is throwing off the car making full power. Need to remove the headers to see where the leak is as it may be where I had the headers port matched to my heads. If that is the case, then it's my fault for being hp greedy.
However, if it's were the pipes merge, then it's another story as I had another set of Hookers leak in the same spot. Souldn't say anything until I have the proper evidence, but I'm a little leary right now regarding Hooker headers as that would be two sets in a row.
Old Feb 28, 2007 | 05:25 PM
d48mclain's Avatar
d48mclain
I second the motion!
To High Flow cat
