Front-End Suspension Questions
1) How comparable is Spicer to Moog?
2) Any other brands worth looking at...buying...using?
3) Is there any placer cheaper than RockAuto for Moogs or Spicer?
3a) If not, anyone got the latest RockAuto discount code?
4) Out of the 4 front joints, please rate their importance. Ex: Lower (1), Outter (2), Upper (3), Inner (4)??
4a) Is it best to replace all 4 when doing this type of job?
5) Can you mix-and-match different brand for inner and outter without worry?
I might have more questions later.
Lowers are first wear out. Inners and outers should be considered a set if one starts to get sloppy.
RockAuto
My upper ball joint wasn't too bad, but the lower was thrashed. My guess is when you start tearing into it you're going to want to replace everything. I was just going to tear mine down and find the problem and ended up replacing the steering rack, tie rod ends, ball joins, wheel bearings and suspension bushings. It went from a weekend project to never ending and my suspension is still sitting on my work bench.
I think someone is just using the wrong terminology.
Front ball joints: upper, lower, left, right....four in total.
Larry
code5coupe
As of November, Rockauto.com now sells Spicer balljoints. You will not beat their price. They're less than the Moogs too.
The biggest thing I'm looking at is the amount of money it's going to cost.
If I purchase from RockAuto:
SPICER Part # 4011627 (Tie Rod End - Outer) $35.99 (2 for $71.98)
SPICER Part # 4011547 (Tie Rod End - Inner) $23.79 (2 for $47.58)
SPICER Part # 5001069 (Ball Joint - Upper) $70.79 (2 for $141.58)
SPICER Part # 5051153 (Ball Joint - Lower) $63.99 (2 for $127.98)
Total for Spicers(with shipping) = $398.65
(If I find the 5% discount code, then it's ~ $380)
MOOG Part # ES2908RL (Tie Rod End - Outer) $52.79 (2 for $105.58)
MOOG Part # EV200 (Tie Rod End - Inner) $22.79 (2 for $45.58)
MOOG Part # K6346 (Ball Joint - Upper) $72.79 (2 for $145.58)
MOOG Part # K6345 (Ball Joint - Lower) $68.79 (2 for $137.58)
Total for Moogs(with shipping) = $475.12
(If I find the 5% discount code, then it's ~ $457)
Huge difference in price. Even larger if I go with one of those "kit" packages. EX: Mid-American - all 4 + bushings for $249.99; or Ekler's - 3 (no inner tie-rods) and bushings for $219.99. (Not including shipping for either though)
Are Moogs really worth the nearly $80 over Spicers? or the near $220-$260 over these "kits"?
Are there any other brands out there worth naming?
Last edited by stearnman; Mar 15, 2007 at 11:31 PM. Reason: Correcting part numbers & prices.
What's the best deals out there for the package/kit of poly-type bushings? Energy Suspension? Other brands that are good?
I saw that Moog has 2 types of bushings. "Federal-Mogul offers two types of bushings under the Moog brand. One uses conventional rubber, and the second uses a problem-solving thermoplastic design that combines the memory of rubber and strength of plastic"
Has anyone tried these Moog thermalplastic types?
MOOG Part # 4011627 (Tie Rod End - Outer) $35.99 (2 for $71.98)
MOOG Part # 4011547 (Tie Rod End - Inner) $23.79 (2 for $47.58)
MOOG Part # 5001069 (Ball Joint - Upper) $70.79 (2 for $141.58)
MOOG Part # 5051153 (Ball Joint - Lower) $63.99 (2 for $127.98)
Or maybe MOOG/Spicer are all owned by some huge conglomorate like Federal Mogul and just the boxes are different. The MOOG are clearly marked.
Based on reputation, I wouldn't hesitate to use either. Anything else is a gamble and may not even fit.
MOOG # K6345 (lower), # K6346 (upper), # EV200 (inner), & # ES2908RL (outer)
Oh boy...I didn't put the idividual MOOG prices down correctly either. Everything is now corrected in red above.
