ratchet shifter owners, please step inside
with stick shift option.
I would like to install ratchet shifter but it seems that all shifters
are meant to be used with full manual (reverse pattern) valve bodies.
I say this because if you read operating instructions for B&M megashifter
or Hammer shifter it says that to go from in-line gate mode to ratchet mode
shifter must be in drive position (or I guess OD for 4-speed trans).
That is good if you have reverse pattern because you are actually in 1-st gear
but for normal pattern you have to ratchet through all gears to get to first
and when you stop in 1st gear you have to ratchet all the way
to D and than go to in-line mode and to R or P position.
It is similar with Hurst shifters.
Does anybody know if its possible to go from in-line gate mode to ratchet mode
and other way arround in 1st or does shifter really have to be in D position?
Or if you know for a ratchet shifter that works differntly!?
ratchet a lot of times to go from P or R to 1-st gear and vice-versa.
Imagine that in short period of time you have to turn arround your car in
narrow place; you'll have to ratchet that thing like crazy to manoeuvre
the car.
Here is C/P of operating inst. for B&M megashifter:
OPERATION
The B&M Megashifter normally
functions as a straight gate detent
shifter from Park to Reverse to Neutral
to Drive and as a ratchet shifter from
Neutral to all forward gears. Refer to
the following instructions for proper
operation:
STRAIGHT GATE MODE: With the
trigger in the upper position, the shifter
functions in the STRAIGHT GATE
mode. The handle travels in a direct
line forward and backward from Park to
Drive. The trigger must be raised up to
clear the stop gates while going through
the gear positions.
RATCHET SHIFT MODE: The
RATCHET SHIFT mode allows firm,
positive no-miss upshifts and downshifts through all the positions from 1(Low gear) to Neutral. To switch from
STRAIGHT GATE to RATCHET operation, first operate shifter to the Drive
position. The trigger will snap down
approximately 3/4". The shifter is now
in the RATCHET MODE, Drive gear
position. The shifter will only operate in
the RATCHET MODE between Neutral
and First, it will not ratchet to Reverse
or Park. This is done to prevent accidental shifting into Reverse.
the car.
Did you do the transgo kit yet? I've never had soo much fun in my life as when I did mine
I'll set on the side lines here and see how you progress with this ratchet issue, cuz it's one i tabled until someone came along with a good idea..
When I did the transgo, I left it so it will shift by itself if in drive or od, but I soon realized with the stock shifter it's almost impossible to race/shift manually without a ratchet.. (i'm a stick car guy, this is my first automatic car).
-- Joe
-- Joe
I really hate tranny doing something by itself, thats why I'll go with stick shift option.
I still haven't started with upgrading/rebuilding my tranny cause I'm still waiting for converter to come (it was shipped two months ago
)As for shifter I found Hurst Auto/Stick 3 to operate like I would wan't it to, but of course, it's made only for3-speed trannies.
Here is C/P of how that one works:
This is an attractive and high-style, cable-operated ratchet type floor shifter for popular automatic transmissions. It is designed for high performance racing applications, yet equally at home on the street.
Delivers short precise gear changes through an exclusive dual pattern ratchet gear selector
Operates both forward and reverse valve bodies, plus ratchet into neutral feature
Ratchet mechanism may be overridden to reach any gear by pulling the stick up and moving it to desired position
Sturdy black console with anodized aluminum trim plate and embossed with the familiar Hurst logo
Includes bright chrome-plated stick and brushed aluminum T-handle (3/8-16 thread) for added comfort and control
Includes 12-V switch assembly for neutral safety or back-up light connection
Progressively illuminated gear position indicator.
Complete with hardware, heavy-duty 5' shifter cable, and easy to follow installation guide
Positive reverse Loc/Out for NHRA and IHRA requirements
Here's a pic of it:
I wish someone made a T5 tailshaft that would mount the torque beam, because an fbody bellhousing, 4+3 master cyl, 4+3 clutch/flywheel setup would work with a 700R4 driveshaft. I ran some pretty spiffy times with a T5 for a lot of years.
-- Joe
Yes, but with stick/shift option that I'm installing that would mean
that it goes normally to 4-th gear and then you have to ratchet it
to 1st and then back to 4-th and normally to R or P...........so you
would have to move forward in 4-th gear if you don't ratchet it all way down.
something inside shifter?
