'95 A/C Programmer
Old Feb 28, 2007 | 09:31 AM
Duntov's Avatar
Duntov
Default '95 A/C Programmer
I have grown tired of the lazy vent door not putting the air out where I want it. I ordered a new programmer from AC Delco and have not removed the old one as of yet. I already replaced the check valve on the intake, and that did not help.
Anyone have any words of wisdom for removing and replacing it?
Matt
Old Feb 28, 2007 | 02:07 PM
SunCr's Avatar
SunCr
I know that some of the '96 owners have posted that the vacuum connection at the Programmer is the problem - not the Programmer. You might want to make sure that the vacuum harness is snug OR if you have access to a bidirectional scanner, you can send it signals through the CCM link and see if it works. That will rule out the Dash Controls, serial data feed or an individual door solenoid (though I've never seen one of those fail). Otherwise, you've got no choice but to dig in and look at it/replace.
