1.6 Roller Rocker
Old Feb 28, 2007 | 04:40 PM
BlackVette00's Avatar
BlackVette00
Default 1.6 Roller Rocker
will 1.6 Roller Rockers Change the sound of the car at idle? and is it a good upgrade?
Old Feb 28, 2007 | 05:16 PM
bobmic93's Avatar
bobmic93
It will do nothing for the sound. It is a very good upgrade. It should knock off a tenth or two at the track. You wont feel seat of your pants with it. Remember to add behive springs with that mod.
Old Feb 28, 2007 | 05:37 PM
SK.LT1's Avatar
SK.LT1
Old Feb 28, 2007 | 05:59 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
You must stay awake all night thinking up questions! It will be quieter if you do it right.
Old Feb 28, 2007 | 06:12 PM
vader86's Avatar
vader86
No. Yes.
Old Feb 28, 2007 | 08:45 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Wait Vader - they will change the sound of the car at idle - Clang, Clang (if not adjusted properly) - LOL... just could not resist...
Old Feb 28, 2007 | 09:04 PM
gator79's Avatar
gator79
what is the benifet? does it increase cam lift a little over the stock ratio?
Old Feb 28, 2007 | 09:06 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Yes, by 1.6/1.5, which is about 7%
Old Feb 28, 2007 | 09:27 PM
gator79's Avatar
gator79
what are the best ones and best place to get them?
Old Feb 28, 2007 | 10:22 PM
Steel Breeze's Avatar
Steel Breeze
Roughly .031", just bought me a pair from vinnies87. Not sure why he sold them. Perhaps it's the clang, clang, clang, if not adjusted properly.
So I adjust for zero lash, then go 1 turn. Am I correct? I'm not hijacking your thread gator79. It may be usefull info for you as well...
Old Feb 28, 2007 | 10:28 PM
tequilaboy's Avatar
tequilaboy
They will sound a little bit like a sewing machine if you get your ear close enough.
Old Feb 28, 2007 | 10:57 PM
CentralCoaster
I've been eyeing the Comp Cams Pro Magnums, they are steel and more durable than the aluminum ones, and they claim they have less rotational inertia than the aluminum ones.
$260 from Summit.
Old Feb 28, 2007 | 11:23 PM
BlackVette00
how much HP do you get out of it?
Old Feb 28, 2007 | 11:26 PM
CentralCoaster
Dunno. Dyno's aren't my thing.
But if it gave me 1/10th at track I'd be pleased.
As mentioned, you probably won't feel 10-hp, so if you're not racing, I don't see the point in spending the dough.
Old Mar 1, 2007 | 12:46 AM
Steel Breeze
I think 10 -13HP is what the general consensus is. I read an artical on staggering 1.5's, and 1.6's. I remember it gave the same HP as the straight 1.6's, but the engine idled better, was the claim...
Old Mar 1, 2007 | 06:41 AM
Atok's Avatar
Atok
When I installed 1.6RR on my '95 with Corsa exhaust it made the idle deeper, but barely noticeable. It changed the sound at cruise as well, even my wife noticed that.
To 1.6 Roller Rocker
