Testing the Map Sensor
Old Feb 28, 2007 | 06:56 PM
jam019's Avatar
jam019
Default Testing the Map Sensor
Hello fellow Corvette lovers, I have a question,can any one tell me how I can perform a diagnostic test of the Map Sensor on my 90' Vette.
Any info would be greatly appreciated.
Old Feb 28, 2007 | 07:09 PM
Road Agent's Avatar
Road Agent
Swap it with a known good one.
Old Feb 28, 2007 | 07:36 PM
C4Techie's Avatar
C4Techie
Suck on the hose and see if the volts or ohms change. You could plug and unplug the vacuum hose while you observe the changes, or you can use a vacuum pump and compare your readings to those in your FSM.
To Testing the Map Sensor
