Bright Lights
Old Mar 1, 2007 | 08:08 PM
BlackVette00's Avatar
BlackVette00
Default Bright Lights
Does anyone own, or seen what these lights are like, if they are really bright, and everything fit up right
http://cgi.ebay.com/ebaymotors/DIAMO...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/87-97...QQcmdZViewItem
Old Mar 1, 2007 | 08:19 PM
cdnguyred88's Avatar
cdnguyred88
For the price it seems to cheap, but I don't know about these replacemnet bulbs and housings??? I run Hella housings with 100/80 watt bulbs in mine.
Old Mar 2, 2007 | 07:51 AM
95 blue pig's Avatar
95 blue pig
Default mine are crap
I bought A set off E-bay, that look just like the ones pictured,with magnifing lens in center and the small street glow bulbs. The reflector seems A poor design.I got much better lighting from the stock halogen sealed beams
Old Mar 2, 2007 | 07:55 AM
95 blue pig
Oh yea; I had to remove the small street glow bulbs and plug the holes to get them to fit in the buckets on my 1995 vette
Old Mar 2, 2007 | 02:24 PM
rickneworleansla's Avatar
rickneworleansla
Those look very similar to the APC diamond cut lenses I bought from PepBoys. No modifications were needed on mine. I paid about $40 for them. The clear lenses made a big difference in increasing the light. The key is to get a good bulb to go with them. When they get dusty or dirty they perform more like the stock sealed lights. Mine also seem a good bit lighter than the sealed beams.
Old Mar 2, 2007 | 02:53 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
There is a lot of junk out there, when it comes to lighting.
Seems like the cooler it is, the worse it performs.
I'd stick to proven components; Hella, Cibie, Bosch, Marchal...for housings; and Osram-Sylvania, Philips-Narva, and Tungsram-GE for bulbs. (No Blue or super-white, either......)
I've played with the "diamond-cut", the cheap No-Names, and the blue bulbs...I've come back to simple, pricey-but-effective Hella and Osram or Tungsram.
Larry
code5coupe
Old Mar 2, 2007 | 03:19 PM
hardlight's Avatar
hardlight
I agree, you get what you pay for. I have the same set up as above, maybe one bulb strength stronger, 130/100 ??. Anyway, my 66 yr old eyes are now pretty satisfied. The Hella setup is way better but not quite as good as the Xenon HID in my new daily driver.
Old Mar 2, 2007 | 07:34 PM
carlton_fritz's Avatar
carlton_fritz
St. Jude Donor '08-'09
If I can take the time to figure out how to replace my headlights, I'm going with Sylvania silverstars.
Old Mar 2, 2007 | 07:45 PM
Matt383's Avatar
Matt383
From: 2003 Points Champ Great Lakes Corvette Challenge; 2006/2007 Winner MSD True Street
I use those in my GMC pick up.
I like em.
This also made me think about my vette.
I have the original OEM headlights in still.
Never changed and still work.
They are almost 20 years old now.
Is that normal?
Matt383
Old Mar 2, 2007 | 09:33 PM
carlton_fritz
I like em.
Is that normal?
Matt383
I've only had mine for 2 months. I don't know if that is normal for a Vette. Is changing the headlight difficult on a Corvette?
Old Mar 3, 2007 | 09:13 AM
NocarbutaVetteforme's Avatar
NocarbutaVetteforme
No, changing the headlights in a Corvette isn't that hard. As for the light kits, you may want to verify that they will pass inspection. I didn't have a problem with mine but a friend put in an aftermarket kit and the person doing the inspecting said it had to have a DOT certification stamp. Although I do like the idea of the projector lights coupled with a set of the McCullough HID conversion kits. And btw, I have a set of similar to those and the light is way better than before. The only thing I would recommend is getting a better set of H4s than what came with the kit.
Old Mar 3, 2007 | 02:00 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
That's what I did. I like my SilverStars... LOT's MORE light than the stock bulbs. (about TWICE as much)
Old Mar 3, 2007 | 05:10 PM
carlton_fritz
That's what I want. More light.
Old Mar 3, 2007 | 05:31 PM
BlackVette00
so replacing the bulb is easy?
Old Mar 3, 2007 | 06:25 PM
runner140*'s Avatar
runner140*
I have a 96', and purchased them as my second or third set of lights.
I'm on my 5th set now and they are Sylvania's Silverstar "Cool Blue".
I drive seven days a week, mostly at dark and need as much light as I can get.
Before the "Cool Blues", I had a set of H-4's. Both were ok.
Old Mar 4, 2007 | 01:21 AM
BlackVette00
are the H4s a big difference then stock? and is it easy to take the bulb out?
Old Mar 4, 2007 | 04:26 PM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
Huge difference. And as for ease of replacement, very. With a Phillips screwdriver and a small socket (don't remember which off the top of my head), you're done with both of them in about twenty minutes. Go read this thread:
http://forums.corvetteforum.com/show....php?t=1618455
To Bright Lights
Old Mar 4, 2007 | 10:54 PM
Impala Balko's Avatar
Impala Balko
I bought similar lights to these from Autozone and they are made from a company from "Adjure" But as far as light bulbs go I went a slightly different route.
Old Mar 5, 2007 | 10:42 AM
rickneworleansla
Whats the boxes attached to the lights for? I know HID lights have something similar.
Old Mar 5, 2007 | 02:44 PM
Impala Balko
These are 10,000kelvin Bi-Xenon HID's Those are the ballasts/ignitors that are attached
