drainging radiator,pit cock
Old Mar 5, 2007 | 12:06 PM
grove's Avatar
grove
Default drainging radiator,pit ****
Where is the pit **** located on a 95 vert? Not much rom to find it,trying to drain radiator.
Old Mar 5, 2007 | 12:16 PM
STL94LT1's Avatar
STL94LT1
Lower right (passenger) side.
Old Mar 5, 2007 | 02:38 PM
LannyL81's Avatar
LannyL81
Its not like the old style that you can see. Its on the back side of the radiator, in a recessed area. Have to use a pair of flat nose pliers to open and close it. Be careful though...only plastic.
There is a small hole in the radiator shroud for the coolant to drain out of....sure be nice if there was a hose attached to the radiator so that coolant does not flow under the radiator.
Later
Old Mar 5, 2007 | 02:49 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Remove the radiator cap, too, to de-pressurize the system and allow coolant to flow more rapidly.
Old Mar 5, 2007 | 10:14 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Note: If you break that little surcker, drive down to your handy dandy auto parts store, in SOMETHING ELSE and get another one for about 'tree' dollars.
Old Mar 6, 2007 | 12:38 AM
SJW's Avatar
SJW
If you want to also drain the engine block, you'll need to remove the knock sensors. They're installed in the holes that formerly were the block drains on SBC engines.
Be well,
SJW
Old Mar 6, 2007 | 03:27 AM
AZC4Guy's Avatar
AZC4Guy
petcock
To drainging radiator,pit cock
