spare tire light ?
Old Mar 5, 2007 | 04:07 PM
corvettedan22's Avatar
corvettedan22
Default spare tire light ?
I have seen this light sitting down there but have never seen it go off.
What makes it go on ?
Dan
Old Mar 5, 2007 | 04:08 PM
87vette's Avatar
87vette
It is part of the courtesy light when you open the doors. When you shut it it takes a couple secs for it to go off.
Old Mar 5, 2007 | 04:43 PM
LT1vette's Avatar
LT1vette
Default Light????
Where is that light you are talking about? Is it on all C4's up to 96 or just some years?
TIA
Old Mar 5, 2007 | 05:34 PM
sxyvet's Avatar
sxyvet
hi there guys,
where you turn on the main light switch ,well on the side there is a lever that slights up and down!
when you turn the lever on it will bring the cabin lights and the spare tyre lights on!
well that is for 91-96 any way,not sure about 84-90 though!!!
cheers
glen
Old Mar 5, 2007 | 06:29 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
My 84 has got the light as well as my '91.
Old Mar 5, 2007 | 07:34 PM
Bob CTS's Avatar
Bob CTS
yep, I have it on the 86 it's on if the headlights are on or if I open the rear hatch, probably on if the doors are open as well.
Old Mar 5, 2007 | 07:49 PM
87 rag's Avatar
87 rag
I love my spare tire light.
First time I noticed it I figured I had a bulb that had fallen out of somewhere and was hanging down. When I realized it was supposed to be there I thought....that's awesome.
Old Mar 5, 2007 | 07:56 PM
c4cruiser's Avatar
c4cruiser
If you ever need to replace the light housing by the spare, it's the same one that the C5 uses for a license plate light!!
Old Mar 6, 2007 | 07:23 PM
corvettedan22
Well it didnt go on when I opened the door.
Next ill check if they go on with the head lights.
Then the bulb.
Old Mar 6, 2007 | 10:57 PM
Dads90's Avatar
Dads90
I don't think it goes on with the door opening. The slide lever on the headlight switch will turn it on.
Old Mar 7, 2007 | 12:09 AM
Trog's Avatar
Trog
My '90 works in conjuntion w/ the interior lights... So, door open & inside lights on, its on. Same if I use the dimmer control to turn on the inside lights. A nice feature after dark for getting around the car if you happen to open/hold the door for your woman.
To spare tire light ?
