89 Bose Door Speaker box removal
Old Oct 9, 2001 | 10:26 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default 89 Bose Door Speaker box removal
I think I will get a better response in Tech...
Someone posted this some time ago.. I cannot find the copy I had.. anyone have the info on how to remove them?
Jeff
Old Oct 9, 2001 | 10:42 PM
BBA's Avatar
BBA
Default Re: 89 Bose Door Speaker box removal (-=Jeff=-)
For me, I just unbolted the aluminum window mechanism mounting plate bolts. Then slide the plate over, remove the screws for the bose unit, pry it loose ( has goey stuff holding it tight ) and work it out. The wires unplug from it, once you get it a little loose.
