From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Probably - My 92 came with hollowed cats, I need working cats to pass emissions. Found someone with a low mileage set from a later year (95 or 96). The cats mount a little differently on the later year, had to remove a small part of a mounting the 92 does not use. Put a plug in the after cat bung (92 only uses O2 sensors before the cat). And it all attached fine.
They are identical, the only difference is 96 with the extra 02 sensor on the drivers side, but you can buy a plug for that, otherwise they are the same.
If you want to buy a stock 95 system, send me a PM- I need to clean out my basement!
Good luck trying to sell it, I have never seen one sell ever. Most have been given away for the price of pick up. I've received two for free and have also given away two for free.
Now if you were to throw away the exhaust, cut the tips off first, because those you could sell. I got $25 for mine.
Funny, 'cause I know you're right. [/imagine smiley with cut-off wheel inserted here]
