timing question????
Old Oct 10, 2001 | 09:46 AM
mikes84vette's Avatar
mikes84vette
Default timing question????
what is the base timing setting on my '84? what is the best optimal setting, for best performance?
[Modified by mikes84vette, 7:59 AM 10/10/2001]
[Modified by mikes84vette, 8:02 AM 10/10/2001]
[Modified by mikes84vette, 8:04 AM 10/10/2001]
Old Oct 10, 2001 | 12:51 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: timing question???? (mikes84vette)
Base timing for my '86 is 6 degrees before top dead center. You should have a sticker someplace in the engine compartment that tells what it should be for your car. You know about disconnecting the electronic spark timing wire before setting base timing? It is a little weather pack connector on a single wire near the right side of the wiper motor. It comes out of a large bunch of wires there. After you set the timing you need to shut off the car, re-connnect the wire, and clear the codes from the computer.
