Where can I pull 12V Ignition power from ?
Old Mar 8, 2007 | 10:48 AM
Vic'89's Avatar
Vic'89
Default Where can I pull 12V Ignition power from ?
I need a 12V power supply that only supplies power once the car is running.
Does anyone know what I can tap into easily in the Drivers side of an L98.
Vic
Old Mar 8, 2007 | 11:19 AM
scranage's Avatar
scranage
Common line on the injectors is ignition hot. I prefer to put in a seperate fuse block with a relay myself, but the other is obviously easier.
Old Mar 8, 2007 | 11:22 AM
Aardwolf's Avatar
Aardwolf
Cig. lighter? Power seat wires?
Old Mar 8, 2007 | 04:59 PM
Keystring's Avatar
Keystring
My radiator cooling fan was wired to the windshield wiper harness.
Only comes on when the key is on.
Old Mar 8, 2007 | 05:03 PM
mseven's Avatar
mseven
I am using the AIR for 02(now discontinued on car) and used the electrical (fsm v.2) to find and tap into the wiring harness going to the ECM as switched sources for shift light etc.
Old Mar 8, 2007 | 06:53 PM
C4Techie's Avatar
C4Techie
Vic
A switched 12 volt power supply is one thing, but only when running complicates matters. You could come off of the oil pressure switch if your usage will tolerate the 2 second feed from the fuel pump relay when the ignition switch is turned to on. Otherwise you could add another oil pressure switch.
Old Mar 8, 2007 | 08:01 PM
vader86's Avatar
vader86
Wiper motor was wired to my main fan relay to keep the fan running on mine when I bought it.
To Where can I pull 12V Ignition power from ?
