95 Ignition & Dash Problem
Old Mar 9, 2007 | 08:18 PM
RONJON851's Avatar
RONJON851
Default 95 Ignition & Dash Problem
This Is Wild,i Haven't A Clue.95 Vert 55k Original Condition.i Turn The Ignition Switch And...... Nothing.on The Center Display Service Asr Light Is On,asr Off Light Is On ,battery Light Is On,volt Gauge Is At 12 Or 14v Whatever Is The Normal From What I Remember.i Turn On The Parking Lights And Have No Illumination Where The Odometer And Fuel Display Is.parking Lights Go On,headlights Function.i Went Through Each Fuse And Found That Everyone Of Them Is Good.under Hoood Fuses Are Good.battery Might Need Replacement And Was Charged But Could Be Faulty.if The Battery Is Low Enough Could It Cause This?any Help Appreciated!!!!!!
