Hey guys im about to buy a borla catback sysyem off of a forum member off his 95 lt1, will this work on my 92 lt1 and on this system does it matter if its auto/stick need help on this one thanks mike
It will fit. The hardest part will be removal of the old system, soak all the bolts on the drivers side cat.
There are two studs and one bolt on the drivers side, unless they've been changed in the past, be prepared to replace them for the chance of snapping them off is high.
The passenger side is a slip fit with a clamp.
It may take a little force to remove it. What I do is after loosening up all the bolts at the front is to drop the mufflers and I use my floorjack with a jack a vette installed and kind of slam it back till it comes off.
Kind of hard to describe without having the proper pics.
Do a search on jack a vette or Corvette gadget man(no links please from the rest of you) I've included pics on what that looks like as well.
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
It's a bolt-on, no worries. It'll likely have an O2 sensor bung on the right side that I don't believe you'll need for your '92. Get a universal 18mm oil plug at your parts store to plug it with, fits perfectly.
