Wheel studs- tread size?
Old Mar 10, 2007 | 01:22 PM
77vetteuk's Avatar
77vetteuk
Default Wheel studs- tread size?
Removed my rear wheels off the '91 this morning to go get new tires on them, i dont trust the shop with jacking/removing the rims after the last tire guy jacked up my C3 right on the oil pan
Anyway, found one of the wheel nuts to be cross-threaded on removal, lookes like it was impact wrenched on by the previous owner/shop? And these C4 wheel nut seem soft?
The wheel stud is a little chewed up at the end, want to go buy a die on monday to clean up the thread before i refit the wheels,
Anyone know, off hand, what thread size the studs are?
Cheers
Old Mar 10, 2007 | 03:56 PM
Eike's Avatar
Eike
In Germany we call it M12x1.5
Does that help?
Old Mar 10, 2007 | 05:15 PM
c4cruiser's Avatar
c4cruiser
Also, the lug nuts have a 60 degree taper on the seats. The Vette lug nuts have the outside threads for the caps but most mid-size and larger GM cars that have alloy wheels use the same thread size.
Getting a Vette lug nut may run $3 per, but the generic GM metric lug nuts or the parts store versions run less than a buck each.
Old Mar 10, 2007 | 06:48 PM
77vetteuk's Avatar
77vetteuk
Does that help?
Excellent, just what i was after,
Thanks for your help
To Wheel studs- tread size?
