Dual converters?
Old Mar 11, 2007 | 04:44 PM
TPeye's Avatar
TPeye
Default Dual converters?
I have a '90 with a six speed and the L98. I want to put in a 2 1/2" front Y pipe with regular converters mounted in place of the pre cats, and remove the factory main cat. Has anybody done this? How did it work?
Old Mar 11, 2007 | 04:49 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Indeed you have the right idea.
Each front Y will flow 560cfm but you won't find a single main cat to flow near that.
The 3" pipe in each Y will flow 960cfm, enough to sustain ~440chp.
I think you can find bullet cats that will each flow 480cfm or so.
Old Mar 11, 2007 | 06:05 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Another way to go with even less restriction, is run true duals with a crossover. You can run with a high flow bullet on each side up close to the flange if you like. www.corvettecentral.com
To Dual converters?
