Thread size for DeWitt radiator EOC holes
Old Mar 11, 2007 | 06:23 PM
ScaryFast's Avatar
ScaryFast
Default Thread size for DeWitt radiator EOC holes
Tom (or anyone) - what is the thread size and pitch for the fittings to the oil cooler in your radiators (specifically A90E).
I have 10 AN hose and ends for my current exteral OC, it looks like you're using NPT threads and I need an adaptor.
Thanks in advance.
Old Mar 11, 2007 | 07:46 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
3/4 x 16 straight thread O-ring seal aka #8 SAE.
Old Mar 11, 2007 | 08:40 PM
ScaryFast's Avatar
ScaryFast
I should have just PM'd you, you know damn near everything about these cars...
Thanks!
Old Mar 11, 2007 | 08:46 PM
Corvette Kid
Thanks!
Thanks but hardly. That's the info Tom gave me when I got mine. Don't confuse the #8 SAE with AN numbers, they are not equivalents.
Old Mar 11, 2007 | 10:58 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
thanks CK!
Old Mar 12, 2007 | 10:48 AM
ScaryFast's Avatar
ScaryFast
Tom, thanks for checking in. Rad looks great, sorry for all the messages on your office machine...I got a little over-anxious.
I decided to run both the internal EOC and my external to keep temps down. I was quickly exceeding 250* on track with the external, I'd like those temps down in the 220 range if possible.
Anyway, do you sell any adaptors from SAE to AN threads? I'm not sure where to get them around here and this needs to be in and running by Friday...
Thanks again.
Old Mar 12, 2007 | 01:16 PM
Solo2GS's Avatar
Solo2GS
St. Jude Donor '07
Look for a local hose and fitting shop that speciallizes in this stuff.
If you can't find anything local you can always call Orme Brothers @ 818-885-1414 / www.ormebrothers.com
I got all my fittings from them when I hooked up my Dewitt Radiator with EOC.
Basically you will have the #8 SAE threaded O-ring fitting into the radiator then another 10AN fitting to it.
The fitting is about $15.
Old Mar 12, 2007 | 01:36 PM
Solo2GS's Avatar
Solo2GS
St. Jude Donor '07
Default Pictures
Pictures always help for anyone that is searching this subject so I thought I would add some.
The 2 fittings on the radiator side
MOCAL sandwich adapter with built in 180F thermostat from Racer Parts Wholesale
Old Mar 12, 2007 | 02:18 PM
ScaryFast's Avatar
ScaryFast
I was able to call around and I found everything at a local speed shop that I didn't know existed. They had to order the SAE to AN adapters but had everything else. It's turning into a mess under there...
Block line to radiator is SAE / AN, then the line from the DW rad to the external cooler is AN / SAE (different size, of course), then back to the block. My oil system is going to be 11 qts...if I ever have temp issues again this car is going to the bottom of a lake.
Old Mar 12, 2007 | 02:19 PM
ScaryFast's Avatar
ScaryFast
One more thing - what is the torque spec to the radiator?
The adaptors are steel, I don't want to over tighten them and damage the aluminum thread.
BTW, for those who also might need this info, Summit has all of the fittings, hoses, and adaptors, I just wanted them today so I could finish tonight.
Old Mar 12, 2007 | 03:05 PM
Solo2GS's Avatar
Solo2GS
St. Jude Donor '07
I used the German torque spec of goodentite!
They have an O-ring to seal.
If you have not assembled the hoses yet, I found using a vise to hold one end still while I wiggles on the stainless steel hose to it worked well.
I found this online to help me figure out how to assemble the fittings as I never did it before. Has a variety of different fittings and hoses and how to guides.
http://www.goodridge.net/usa/pdf/mot...llation_ms.pdf
Old Mar 12, 2007 | 05:15 PM
Corvette Kid
Steel fittings are what I used too. Good and snug but don't go overboard. And hold the fittings with a wrench when tightening the hoses onto them. Don't forget to lube the O-ring a bit.
Old Mar 13, 2007 | 04:36 PM
ScaryFast's Avatar
ScaryFast
O-ring...o-ring?
I don't have an o-ring on the fittings I got. Should I go buy some or will some thread sealer be enough?
Old Mar 13, 2007 | 05:47 PM
Solo2GS's Avatar
Solo2GS
St. Jude Donor '07
Does it have a spot for an o-ring at the base? Where the threads end?
Kind of looks like this, but with the o-ring on the nipple end going into the radiator.
Did my best to search for the correct one, but can't find one. Wish I had an extra one laying around!
Old Mar 13, 2007 | 07:48 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Here is it http://store.summitracing.com/partde...5&autoview=sku
Don't pay attention to the 8AN that is really a #8SAE (3/4-16)
Old Mar 14, 2007 | 04:58 PM
ScaryFast's Avatar
ScaryFast
Interesting...I'm glad we have many different thread types from which to choose
Earl's has the 8 SAE and call it 8AN. Aeroquip makes an 8 AN to NPT but no SAE. The local hose and fitting shop sold me an 8AN to 8 SAE but the flange is 37* and the AN flange is 45* so it won't seal.
Cripes. Earl's parts on the way from Summit, looks like my one day job is up to 5 days.
Old Mar 14, 2007 | 05:14 PM
Corvette Kid
Jon, I got mine at a place that sell parts for large trucks.
To Thread size for DeWitt radiator EOC holes
